Author Topic: WTB K24 turbo, or = for 1.6 td, ex. manifold rect. flanged  (Read 4058 times)
August 20, 2008, 04:46:53 pm
Familydiesel
  • 154
« on: August 20, 2008, 04:46:53 pm »
I want to buy a good K14 or K24 turbo, or a turbo that has a trapezoid shaped exhaust inlet flange.  I have the square (8cm X 8cm) exhast flanged down pipe and want to get a turbo that will bolt up to this 85 Jetta 1.6 td engine setup.
Or
I Would consider a good T3 (retangular flanged) exhaust manifold that fits the 1.6td.
Thanks,
Greg
1980 Diesel td pickup, Love that Diesel!
Reply #1August 20, 2008, 10:53:51 pm
westyman
« Reply #1 on: August 20, 2008, 10:53:51 pm »
I have a K24 that had the wastegate actuator removed, valve blocked in the closed position, runs a nice 24 psi wide open on a TD. :-)
Had it on a TD Vanagon.
Reply #2August 22, 2008, 07:20:58 pm
Familydiesel
  • 154
K24 turbo
« Reply #2 on: August 22, 2008, 07:20:58 pm »
Hey Westyman,
Check your pm.
How much do you want for the turbo?  Is it tight without end play or does it need a rebuild?
I have other questions, but I wrote them on a pm.
Thanks,
Greg
Reply #3September 25, 2008, 05:13:29 pm
Familydiesel
  • 154
BOUGHT A K14
« Reply #3 on: September 25, 2008, 05:13:29 pm »
Hi,
I bought a K14 from blkboostedtruck.
Thanks,
Greg
Reply #4September 25, 2008, 05:23:35 pm
« Reply #4 on: September 25, 2008, 05:23:35 pm »
for future reference, the VW diesel T3 uses the same flanges as the K14 and K24, amongst others
