Adjusting Valves? New Valves...New Head
Topic: Adjusting Valves? New Valves...New Head (Read 3396 times)
August 20, 2008, 03:33:59 am
chrisrandle1
User+
August 20, 2008, 03:33:59 am »
Hello;
I am installing new valves into a new head and was wondering how you adjust the valves. I thought I remembered reading somewhere that you grind the top of the valves. If so what is the installed height? Step by step would be nice, but any information that would help me finish this part of the project would be greatly appreciated.
Thanks
-Chris
1992 EcoDiesel - Soon to have P n P Head, T3 Turbo and more!!!
August 20, 2008, 12:40:50 pm
Jet A
August 20, 2008, 12:40:50 pm »
Shims in the lifter buckets. I am not quite there yet, so i dont know the specs.
85 vw golf NA ----> 2b TD Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
August 20, 2008, 01:19:17 pm
Possum79
August 20, 2008, 01:19:17 pm »
The shims are only for Mechanical heads? That eco is hydro isnt it?
I though the hydraulic heads didnt have an adjustment. I dont own one and have never worked on one so I dont know.
1979 VW Rabbit Diesel L
My car may be ugly but im addicted to it.
August 20, 2008, 02:16:11 pm
chrisrandle1
User+
August 20, 2008, 02:16:11 pm »
Yep its Hydro. Anybody...?
August 20, 2008, 02:31:42 pm
Jet A
August 20, 2008, 02:31:42 pm »
My bad....Didnt know they were hydraulic. thats what you get for assuming
August 22, 2008, 07:56:46 am
duffer
August 22, 2008, 07:56:46 am »
See page 28 of the Bentley manual
In the ENGINE Section.
The installeded height of the valve stem
is calculated relative to the gasket
surface (valve cover) of the cylinder
head and the valve seats.
Maximum: 1.5mm
Minimum: 0.5mm
At least, I think I've got that right.
I hope that's what you're looking for.
If it's a "new" cylinder head and "new"
valves the valve stem height should
likely be within those specs.
