Author Topic: oil leaking out of lower dipstick tube.  (Read 2164 times)
August 18, 2008, 10:20:05 pm
turbosuzi
« on: August 18, 2008, 10:20:05 pm »
I have oil leaking out from between the dipstick tube and the hole that it fits into. Is there an o ring that is supposed to fit on to the dipstick tube or how does it seal? I removed it, cleaned it, put RTV on the mating surface, then reinstalled it but after a few miles oil started to leak out again. Anyone elce had this problem?
Reply #1August 18, 2008, 11:19:40 pm
Possum79
  • 276
    • http://www.poscarclub.com
« Reply #1 on: August 18, 2008, 11:19:40 pm »
You may be able to do a search. I have read that a few times and they say there is an oring. Everyone says oring with some silicon in a cleaned tube and hole.
1979 VW Rabbit Diesel L
Reply #2August 19, 2008, 05:14:17 am
« Reply #2 on: August 19, 2008, 05:14:17 am »
Yes I did. Mine had a washer at the bottom to push the oring down I believe. I cleaned the dipstick tube and block with brake cleaner and put another washer down in the hole then RTV then the factory washer and no problems yet.
Reply #3August 19, 2008, 07:04:39 am
turbosuzi
« Reply #3 on: August 19, 2008, 07:04:39 am »
Thanks I will try that today and let you know what happens.
