Author Topic: New Dial Gauge for pump timing  (Read 2703 times)
August 18, 2008, 02:13:22 pm
dieselsmoke
« on: August 18, 2008, 02:13:22 pm »
So I got my new dial gauge to do the pump timing but now I have a question. Once you put the adapter on how far on do you push it onto the dial? How much of the rod should be sticking out of the adapet piece that pushes onto the dial gauge? Thanks!
Reply #1August 18, 2008, 03:35:58 pm
« Reply #1 on: August 18, 2008, 03:35:58 pm »
When it's at TDC, you want at least 2mm(.09") preload so that when you turn it until it stops moving, It stops moving because the plunger did, not because it ran out of travel. Then turn the outer ring until the needle lines up with 0, and turn the engine for the desired reading.
Reply #2August 22, 2008, 06:18:12 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: August 22, 2008, 06:18:12 pm »
how much was your gauge?
Reply #3August 23, 2008, 06:20:03 am
dieselsmoke
« Reply #3 on: August 23, 2008, 06:20:03 am »
I believe I paid around $80 including shipping off of ebay. It came from germany. I came with the camshaft locking plate and injection pump locking pin as well.
Reply #4August 23, 2008, 01:10:03 pm
  • 3468
« Reply #4 on: August 23, 2008, 01:10:03 pm »
Oh wow. Not too bad then. I currently use a ruler for a cam locking plate and a socket extension as a locking pin :P or my friend's hand.
Reply #5August 24, 2008, 06:22:34 am
beowulf
  • 19
« Reply #5 on: August 24, 2008, 06:22:34 am »
Quote from: "dieselsmoke"
A number of people on here have bought the same kit of ebay:
http://cgi.ebay.com/ebaymotors/_Automotive-Tools__VW-Audi-Jetta-Diesel-Injektion-timing-Set-New_W0QQitemZ140260534848QQadnZAutomotiveQ20ToolsQQadiZ2871QQcmdZViewItem?hash=item140260534848&_trkparms=39%3A1|65%3A1|240%3A1318&_trksid=p4506.c0.m245
Diesels do it by squeezing real hard.
Reply #6August 25, 2008, 02:29:59 pm
saurkraut
  • 904
« Reply #6 on: August 25, 2008, 02:29:59 pm »
Quote from: "libbybapa"
timing gauge
The extended urls kinda make scrolling to read a thread a pain.  You can highlight the url and hit the url button.  Delete the first end bracket.  Place it after the url and type the text you want to show between the first end bracket and the second start bracket.  You can hit quote for my post to see the syntax that works for me.  Pretty easy to do once you're used to it.
Andrew[/quote]
Wow, cool.  Now I just have to remeber how to do it.  Thanks!
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #7August 25, 2008, 03:15:09 pm
captainpartytime
  • 39
« Reply #7 on: August 25, 2008, 03:15:09 pm »
-Kerry
1982 Diesel Westfalia Vanagon
1989 Wolfsburg 7-Passenger Vanagon
