Author Topic: Exhaust... could it be too big?  (Read 3231 times)
August 18, 2008, 02:32:16 am
  • 3468
    • McScrubbins Body Wash
« on: August 18, 2008, 02:32:16 am »
I'm building a rather ludacris exhaust for my 1.6....
so im thinking a 3 inch down pipe that goes to a "Y" where it splits to two 2.5 inch pipes that go to the front of the back tires. So essentially its going from just a foot or two of 3 inch to ... 5 inch exhaust.
How much back pressure is required for proper engine operation... I know there is no definate answer but does this seem stupid? I just wanted to have the exhaust in front of the back tires but are my pipes too large? My exhaust fell off once and I ran it with no exhaust for just a day or two and it almost ran better but that was before I changed the pump/boost and that was with stock restrictive down pipe and exhaust. Any thoughts?
Thanks for your time,
Ed.
Reply #1August 18, 2008, 04:12:46 am
flapjack
  • 283
« Reply #1 on: August 18, 2008, 04:12:46 am »
Two 2.5" dia tubes have the are of one 3.5" dia tube.
Being that big won't hurt anything.  I don't think you need back pressure but if you're worried about it, the turbo is a big restriction and provides plenty.
The kids getting close to 200 hp were running 3" dia from the turbo back. I can't find the thread at the moment.
signature
Reply #2August 18, 2008, 05:22:48 am
arb
« Reply #2 on: August 18, 2008, 05:22:48 am »
Should be 2x 2.5" = 3.75"
area = Pie R squared, so:
3.145 * (1.25 x 1.25) x 2
Reply #3August 18, 2008, 06:09:41 am
subsonic
  • 1836
« Reply #3 on: August 18, 2008, 06:09:41 am »
You want as little back preassure as possible in the turbo setup.  About the only debate on large exhausts is flow vs velocity.
Reply #4August 18, 2008, 09:43:24 am
Duzty
  • 34
« Reply #4 on: August 18, 2008, 09:43:24 am »
I have made 204hp on 2½" pipe.
VW Golf mk2 1.9TD - FMIC, GT2860RS - 11mm Pump.
1/4 Mile - 13,24 :twisted:
Reply #5August 18, 2008, 10:21:54 am
arb
« Reply #5 on: August 18, 2008, 10:21:54 am »
Quote from: "libbybapa"
Quote from: "arb"
Pi is 3.14159265....
That rounds off to 3.142 rather than 3.145
Andrew
Yeah, fat fingers ;-)   But its still 3.75"
Reply #6August 18, 2008, 11:50:13 am
saurkraut
  • 904
Re: Exhaust... could it be too big?
« Reply #6 on: August 18, 2008, 11:50:13 am »
Quote from: "Smokey Eddy"
Ed.
Words you'll never see on this forum:
"Jeez, did I screw up by putting too big of a pipe under my VW"
Any back pressure after the turbo is a negative thing.
I have been contemplating a 3" system myself for my '79.
One of the pioneers of this GTD monky business (Jake Russel) found that if he ran his 2.5" down pipe only, he had more measurable power (Gtech) than with the full 2.5" exhaust.  He thought that a 3" system would show more performance than the 2.5" system.
Go for it.  3" is not too big.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #7August 18, 2008, 12:14:05 pm
flapjack
  • 283
« Reply #7 on: August 18, 2008, 12:14:05 pm »
ARB: Here is what I did, please show me where I made a mistake, or show me what you did.
Ignoring wall thickness, the area of two 2.5" dia circles are equal to one 3.54" dia circle
A=pi r2
 For 2.5" dia
    A= pi ( 1.25 )2 = 3.14 * 1.56 = 4.9 square inches
    Two tubes of 2.5" dia = 4.9 sq in * 2 = 9.82 sq inches
For 3.5" dia
    A= pi ( 1.75 )2 = 3.14 * 3.06 = 9.62 square inches
For 3.54" dia
    A= pi ( 1.77 )2 = 3.14 * 3.13 = 9.83 square inches
For 3.75" dia
    A= pi ( 1.88 )2 = 3.14 * 3.53 = 11.1 square inches
signature
Reply #8August 18, 2008, 12:36:37 pm
MJF
  • 581
« Reply #8 on: August 18, 2008, 12:36:37 pm »
When I had dynoed 174hp@crank, I had 3" downpipe with 2,5" exhaust. I measured 0,3bar from downpipe. Then I dropped exhaust, drove just 3" downpipe and got 0,1 seconds off from 1/4 time.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #9August 18, 2008, 02:42:44 pm
  • 3468
« Reply #9 on: August 18, 2008, 02:42:44 pm »
Hmmm I see
Sorry about my math screw up. I should have caught that but it was late when i posted that :P apperently im s'posed to be good at math don't let my prof's read that post about the 5 inch exhaust hahaha
I'm also glad this has a geometry lesson intertwined with the wisdom on downpipes and exhaust. So, to all of you, thanks!
Ed.
