Author Topic: Turn signal issues.  (Read 5722 times)
August 13, 2008, 08:37:14 am
AndrewSE
Turn signal issues.
« on: August 13, 2008, 08:37:14 am »
Ok I thought I had this fixed, but...
So my right side (whole side) signals no longer work again..
I had my relay rebuilt and most of my components (diodes, cap, ic) replaced and it did work for a week.
As of yesterday they no longer work again. The 4-ways work fine..
could I have a short of some sort ? if so why would the 4-ways work and not that side on its own?
just to make a 100% sure.. what number is on the signal relay ?
thankz
Reply #1August 13, 2008, 08:58:52 am
Possum79
  • 276
    • http://www.poscarclub.com
Turn signal issues.
« Reply #1 on: August 13, 2008, 08:58:52 am »
Definitely not a relay issue. If you relay was bad nothing would work. You possibly have a  bad connection somewhere in the turn signal switch wiring or the switch itself is bad. The bentley tells you how to approach that one but its pretty in depth with taking out the fuse panel to probe stuff with a multimeter.
1979 VW Rabbit Diesel L
Reply #2August 13, 2008, 09:13:04 am
blkboostedtruck
  • 1535
Turn signal issues.
« Reply #2 on: August 13, 2008, 09:13:04 am »
check the bulb holders thier known to fail and not give a good connection!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3August 13, 2008, 09:24:12 am
AndrewSE
Turn signal issues.
« Reply #3 on: August 13, 2008, 09:24:12 am »
sounds fun  :roll:
guess I'm going to have to brake down and order the bentley this week.
funny how it worked fine after swaping stuff out on the #60 relay.
but I can understand what you are saying.
As  mentioned the 4-ways work 100% fine so I don't think it is a connection issue with the bolb mounts.
Reply #4August 13, 2008, 09:25:50 am
Possum79
  • 276
Turn signal issues.
« Reply #4 on: August 13, 2008, 09:25:50 am »
Quote from: "blkboostedtruck"
Duane
Wouldn't that also keep his 4 ways from working? I also forgot to mention AndrewSE that they are seperate circuits(kinda) and thats why your 4 ways work but the signal itself won't. I would think that there would be issues with the wiring or the switch that leads up to the relay. They share the same relay so it must be what ever activates it for that side.
Reply #5August 13, 2008, 09:37:13 am
blkboostedtruck
  • 1535
Turn signal issues.
« Reply #5 on: August 13, 2008, 09:37:13 am »
sorry i must of missed that part!
Duane
'66 variant 1500S
Reply #6August 13, 2008, 11:52:39 am
AndrewSE
Turn signal issues.
« Reply #6 on: August 13, 2008, 11:52:39 am »
I think it might be some sort of wiring issue.
now both sides no longer work..
left side I turn it on and i hear it clicking like crazy.. like a short or something..
also noticed the plug that connects to the base of the stearing wheel is cracked a little and one of the small plugs in the jack plug looks a little green. I know this is the plug ,since I removed it and no green light on the dash. Plugged it back and the green light on the dash returns.
going to look at it further when I'm done work.... long as the rain stops in S. ontario !
Reply #7August 13, 2008, 09:25:56 pm
  • 3468
    • McScrubbins Body Wash
Turn signal issues.
« Reply #7 on: August 13, 2008, 09:25:56 pm »
this exactly happened to me TOO!
i changed bulbs and pried the connectors back out as mentioned before and it fixed it except my left turn signal flashes like nuts (i think its just a dieing bulb but who knows) and my reverse lights no longer work (which i know is a seperate everthing because it reads from the tranny) i didn't do anything else extensive
Reply #8August 13, 2008, 09:46:15 pm
catlin_cava
  • 1954
Turn signal issues.
« Reply #8 on: August 13, 2008, 09:46:15 pm »
My cables on the front marker were rusted and it shorted out the 4 ways would work but the right side signals wouldn't. now i keep burning light bulbs...i bought a parts car im just going to swap the entire front harness
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #9August 14, 2008, 01:03:32 am
  • 3468
Turn signal issues.
« Reply #9 on: August 14, 2008, 01:03:32 am »
ooo good idea
where were these rusted leads located?
Reply #10August 14, 2008, 01:53:57 am
catlin_cava
  • 1954
Turn signal issues.
« Reply #10 on: August 14, 2008, 01:53:57 am »
on the connection to the front marker, water had leaked in and corroded the lines
Catlin
Reply #11August 14, 2008, 06:48:55 am
AndrewSE
Turn signal issues.
« Reply #11 on: August 14, 2008, 06:48:55 am »
good idea...
I managed to get the left side to work again.
I have to do some more pooking around to get the other side to work correctly, but I have a good idea what to look for now ! Thankz guys !
on a side note my car is currently in the process of getting my clean air test ! keeping my fingers crossed !
Reply #12August 14, 2008, 05:30:08 pm
  • 3468
Turn signal issues.
« Reply #12 on: August 14, 2008, 05:30:08 pm »
i still don't know where that is. Like in laman's terms?  :P
