Author Topic: headgasket for 40 over rebuilt motor???  (Read 3271 times)
August 12, 2008, 09:11:12 pm
mainer
  • 126
« on: August 12, 2008, 09:11:12 pm »
doing a headgasket on a turbo diesel jetta 1.6 that was rebuilt about 7 yrs ago 40 over.
does it require a special gasket because it was rebuilt 40 thousandths over? or just the standard 1 notch gasket that was in it?
need help asap thanks
_________________
recession definition
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #1August 12, 2008, 09:18:52 pm
53 willys
« Reply #1 on: August 12, 2008, 09:18:52 pm »
you need to measure piston protrusion to find the correct number of notches...
Reply #2August 12, 2008, 09:30:10 pm
mainer
  • 126
« Reply #2 on: August 12, 2008, 09:30:10 pm »
it currently has a 1 notch gasket in it.
i'm just wondering if the 40 over makes a difference when going to buy a new gasket or not. i already have in my possesion a new 1 notch gasket but i just found out that the motor was rebuilt and is 40 thou over.
_________________
Mercedes 240D
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #3August 12, 2008, 09:45:00 pm
blkboostedtruck
  • 1535
« Reply #3 on: August 12, 2008, 09:45:00 pm »
that won't matter use that gasket! notches have to do with piston protrusion 40 over won't hurt the gasket still will work!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #4August 12, 2008, 10:35:13 pm
itzdshtz
  • 94
« Reply #4 on: August 12, 2008, 10:35:13 pm »
A regular gasket will fit, if you have a close look at the piston top, you can see that the 0.040" piston is machined down a bit so that it will fit the stock gasket.
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
Reply #5August 13, 2008, 07:08:33 am
TedV
  • 182
« Reply #5 on: August 13, 2008, 07:08:33 am »
always measure piston protrusion when doing a head gasket.  Only way to know for sure you have the correct # of notch gasket.
Use dowels or old head bolts with their tops removed and a slot cut in them for a flat head screwdriver to spin them  back out to hold the gasket in position while installing the head.  The top edge of the .040 over piston should be beveled to clear the head gasket if it isn't 100% centered, or so we are lead to believe.
