Author Topic: LF 1.6td boost pin and diaphragm  (Read 6097 times)
August 05, 2008, 09:47:12 pm
RandoM
  • 7
« on: August 05, 2008, 09:47:12 pm »
As stated in the title, I've got a 1.9td pump with 10mm head and I need a 1.6td more agressive boost pin
I'm in Quebec, Canada
Reply #1August 06, 2008, 06:18:21 am
spencebm
  • 686
« Reply #1 on: August 06, 2008, 06:18:21 am »
they dont seem to fit too well in my opinion and add too much fuel because they are loose...any one else have this problem?
Ben Spencer
Reply #2August 06, 2008, 06:45:56 am
« Reply #2 on: August 06, 2008, 06:45:56 am »
Isn't the pump the same? i mean people are taking the TDI pump and using parts from AAZ or 1.6TD to make the M-TDI pump.
I don't have any experience but I've not heard anyone complain I don't think. ?
Reply #3August 06, 2008, 07:37:57 am
« Reply #3 on: August 06, 2008, 07:37:57 am »
The Cummins pin was a good fit in my 1.9.
Reply #4August 06, 2008, 06:03:45 pm
Choppercat
  • 42
« Reply #4 on: August 06, 2008, 06:03:45 pm »
You can grind your 1.9 pin: the original pin has a 1 mm recess. Check on the recess to see where how deep your enrichment needle rides on the boost pin and grind a surface at that same range of movement.
After grinding 2mm deep I saw a good improvement so i made it 3mm but it smoked quite a bit even at 15psi until I got an intecooler. Just experiment with yours: you have 3 sides of the pin to play with  :wink:.
Just make sure you polish it to reduce friction with the enrichment needle.
DIESEL SMOKE IS ADDICTIVE!!!
'93 AAZ Golf
'99 Jeep TJ
Project: '51 Willy's CJ-3A AAZ
Reply #5August 07, 2008, 10:07:22 pm
RandoM
  • 7
« Reply #5 on: August 07, 2008, 10:07:22 pm »
Didn't think 'bout that thanks
Reply #6August 08, 2008, 05:08:25 am
Choppercat
  • 42
« Reply #6 on: August 08, 2008, 05:08:25 am »
Where about are you in the Belle province?
'93 AAZ Golf
'99 Jeep TJ
Reply #7August 08, 2008, 07:42:00 am
« Reply #7 on: August 08, 2008, 07:42:00 am »
Quote from: "Choppercat"
Y Just experiment with yours: you have 3 sides of the pin to play with  :wink:.
You could grind more than 3 considering the narrow contact point the pin rides on.
