Volumetric efficiency of 1.6td?
Topic: Volumetric efficiency of 1.6td? (Read 2823 times)
August 04, 2008, 10:28:07 am
zaprzal
August 04, 2008, 10:28:07 am »
What is Volumetric efficiency of stock 1.6td, 1.6td with ported head, 1.6td with 1.9 head?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm
August 04, 2008, 11:00:02 am
dillenger1
August 04, 2008, 11:00:02 am »
I thought that had to do with turbos?Ive never heard an engine rated in those terms.It may just be me though,im still a newb.
1.6td in toyota pickup
10mm head ,t3 intercooled.
August 04, 2008, 12:10:23 pm
gigaz2
August 04, 2008, 12:10:23 pm »
VE has to do with flow, cam and basically all the other physical dimensions of the engine.
if you change headers, VE changes.
I don't remember if the SAE paper adresses that, but its a good read nonetheless
August 05, 2008, 04:29:51 am
zaprzal
August 05, 2008, 04:29:51 am »
do you know how much is it for 1.6td with stock cam? It isn't constant, it change a bit in differen rpm range? right?
August 05, 2008, 06:23:59 am
gigaz2
August 05, 2008, 06:23:59 am »
its a curve, follows the torque curve, but not quite.
I couldn't found any plots online, and don't recall seeing one for a 1.6, I'm pretty sure that if there is one, its on the SAE papers.
you can also calculate it from the torque VS BSFC curve I believe.
wiki:
http://en.wikipedia.org/wiki/Volumetric_efficiency
better:
http://tunertools.com/articles/volumetric-efficiency.asp
