Author Topic: IP Leak & Reseal  (Read 5155 times)
July 31, 2008, 07:48:16 am
91 ECO
IP Leak & Reseal
« on: July 31, 2008, 07:48:16 am »
My pump is leaking from the junction of the main pump body and the part that has the injector line connectors.  What is that seal called?  I have searched through some threads and determined that I don't want to try replacing the seal on my own.  Giles rebuilt the pump about a year ago and I don't want to mess up a good pump trying to do something that's potentially over my head.  If I lived in Canada, I would send it to Giles.  Living in the States created a nightmare getting him my pump for the original rebuild (I was the one that had my pump stolen out of the box in transit).  I have a diesel shop in town that seems to know what they are doing and I don't want to sound like a dummy when I talk to them.
The one bright spot in this whole deal is that it will be easy to change the injector behind the LDA.
Reply #1July 31, 2008, 08:20:11 am
IP Leak & Reseal
« Reply #1 on: July 31, 2008, 08:20:11 am »
You can actually change that seal on the car.
Someone will post the link I'll bet.
It's just a O ring as far as what it's called..
Reply #2July 31, 2008, 09:12:50 am
Possum79
  • 276
    • http://www.poscarclub.com
IP Leak & Reseal
« Reply #2 on: July 31, 2008, 09:12:50 am »
Its in the FAQ the link to this site. I found it a while ago by accident. Someone else posted the link to this
http://crustycrank.com/rabbit.htm#vepump
1979 VW Rabbit Diesel L
My car may be ugly but im addicted to it.
Reply #3July 31, 2008, 10:47:01 am
91 ECO
IP Leak & Reseal
« Reply #3 on: July 31, 2008, 10:47:01 am »
Thanks for the link.  That looks reasonable enough to work on myself.  I need to pull the pump to make sure that my diagnosis on the leak is accurate.
Reply #4July 31, 2008, 10:54:23 am
suomistyler
  • 15
IP Leak & Reseal
« Reply #4 on: July 31, 2008, 10:54:23 am »
I just had mine resealed a month ago through a guy on Ebay. His username on ebay is red--rider.
http://cgi.ebay.ca/VW-Diesel-Fuel-Injection-Pump-Resealed_W0QQitemZ250274375643QQihZ015QQcategoryZ33555QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
He's resealed over 200 of these pumps without any negative feedback and the cost is only $115. he's been a diesel mechanic for 25 years.
He replaces every seal and guarantees your pump leak free for 1 year.
If you want to know the source of the leak on your pump, then you might want to try this: Clean the pump and dry it well, then put flour around the seal you think is leaking. Go for a spin in the car and if the flour gets wet with diesel, you have your leaky seal.
EDIT: i just noticed that you reside in North Carolina....the same state as the guy on ebay. He resides in Lincolnton, he may even be within driving distance for you.
Reply #5July 31, 2008, 12:53:25 pm
Sam Johnson
  • 55
Post Subject
« Reply #5 on: July 31, 2008, 12:53:25 pm »
After thinking about the pros and cons of trying to install the o-ring with the IP on the motor I decided to have my IP resealed by red-rider.  Even shipping it back and forth from Tucson, AZ it cost less than $175 and only a week.
The workmanship was quick and professional and my IP is working perfectly with no leaks.  If you live in NC I would contact him and take my IP to him to be resealed.  You should have 3-4 days total turn around.
Good Luck,  Sam
Tucson, AZ
Reply #6July 31, 2008, 08:49:53 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
IP Leak & Reseal
« Reply #6 on: July 31, 2008, 08:49:53 pm »
yeah i changed mine pretty easily. i ordered mine from this dude in quebec and i modified a flat head driver to get the old one out (its really in there because you have to mallet the new one in) i basically destroyed the old seal but be careful not to mark up the sealing surface of the pump!!!!!! the site isssss
http://www.veg-injection-service.com/store/index.php?main_page=product_info&products_id=15
he takes pay pal
cheers,
Ed.
Ed
Reply #7August 01, 2008, 07:45:23 am
91 ECO
IP Leak & Reseal
« Reply #7 on: August 01, 2008, 07:45:23 am »
Thanks for the info on the ebay guy.  I will check it out.
Reply #8August 01, 2008, 09:57:38 am
suomistyler
  • 15
IP Leak & Reseal
« Reply #8 on: August 01, 2008, 09:57:38 am »
no problem...anything to help a fellow dieseldude out... :wink:
