Author Topic: Wholesale parts for all your cars  (Read 11852 times)
July 31, 2008, 07:17:33 am
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
« on: July 31, 2008, 07:17:33 am »
Hey Guys,
We wanted to let you all know that we are offering a complete selection of maintenance parts for your cars; VW and non VW. We have everything from pads and rotors to glowplugs and injectors.
Here is a small sample of some of the items we have
1.5/1.6 Timing Belt and Tensioner         37.50 (ContiTech belt, GMB Tensioner)
1.9 AAZ Timing Belt and Tensioner         66.65 -90.44 depending on year
1.9 AHU Timing Belt               32.65
1.9 AHU Tensioner               57.81
1.9 AHU Roller                  32.48
Bosch Duraterm Glowplugs            12.50
1.9 AAZ Metal Headgasket            45.50
Rubber Valve Cover Upgrade (Studs and VC gasket)    20.00
We can get pretty much any part you need, including rebuild parts, just ask.
Please email us with your list of parts and we will reply with prices. Emails are normally answered within 24 hours, excluding weekends.
Thanks Guys,
Giles
[email protected]
905-940-2266
« Last Edit: August 24, 2009, 12:33:46 pm by Giles@PerformanceDiesel »
Reply #1August 29, 2008, 01:20:19 pm
duffer
  • 164
« Reply #1 on: August 29, 2008, 01:20:19 pm »
Do you sell Bosch VE Injection Pump re-seal kits
    for the 1.6l TD and n/a?
Reply #2August 29, 2008, 01:48:48 pm
  • 221
Seal kits
« Reply #2 on: August 29, 2008, 01:48:48 pm »
Hi
yes we can sell you a complete re-seal kit, if you really insist
that kit is OEM Bosch BTW
Giles
Reply #3August 30, 2008, 08:50:05 am
duffer
  • 164
« Reply #3 on: August 30, 2008, 08:50:05 am »
Oh, Great!
   I'll probably need three DGK 121 kits.
   for the TD pumps, I have lying around.
   and a DGK 126 for the extra N/A pump.
   Yes, I'd prefer the original Bosch parts
   rather than the fake Chinese rubbish
   found on e-bay, et al.
   Thank you very much for such a prompt
   response.
Reply #4August 30, 2008, 09:23:26 am
  • 221
kits
« Reply #4 on: August 30, 2008, 09:23:26 am »
ok no problem
i use a different NA kit
1 467 010 059 is that ok?
giles
Reply #5August 31, 2008, 07:32:54 am
duffer
  • 164
Re: kits
« Reply #5 on: August 31, 2008, 07:32:54 am »
Quote from: "Giles@PerformanceDiesel"
ok no problem
giles
  Well, actually I don't recognise that
  part number, however, relying
  entirely upon your universally acclaimed
  expertise  :) , I would assume that this
  kit is perfectly compatible and that
  the seals won't disintegrate when coming
  into contact with diesel fuel.
  Incidentally, I'm aware that you make your
  living re-sealing inj. pumps, etc., consequently,
  seeking to buy kits for a DIY might seem
  mildly offensive. However, these are just
  some pumps I know nothing about and, thus,
  not really worth spending any significant
  amount of money on them.
  Again, thank you for you response.
Reply #6January 09, 2009, 07:36:27 am
BioDieselVW
  • 93
« Reply #6 on: January 09, 2009, 07:36:27 am »
Can you get a 1.6TD Oil returnline for a kkk24 turbo?
81 Caddy 1.6 TD
Callaway Intercooler
4in Exhaust Stack
Super Pump !
Reply #7November 11, 2009, 08:45:37 am
HoaftNom73
  • 5
    [url=http://russian-brides-best.com/]belarus singles[/url]
    • beautiful dating
« Reply #7 on: November 11, 2009, 08:45:37 am »
Thanks for the reminder Christina Just ordered it right now Your designs ROCK
Reply #8November 12, 2009, 11:35:40 am
GEE-BEE
  • 1604
Re: Wholesale parts for all your cars
« Reply #8 on: November 12, 2009, 11:35:40 am »
I NEED A 1.9 AAZ TURBO K03 OIL FEED LINE  ( NEW )
AND THE LARGE COOLANT LINE ( METAL ) NEW ALSO
LET ME KNOW
[email protected]
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #9March 12, 2010, 07:10:31 am
fck
  • 70
« Reply #9 on: March 12, 2010, 07:10:31 am »
you guys wouldn't happen to have a tenisoner pulley for the 1.6n/a motor with a/c, would you? for the accessory belt?
