Author Topic: Would you pay to add squirters to your NA block?  (Read 8654 times)
Reply #15August 01, 2008, 02:15:18 am
jimbote
  • 168
squirter source....??
« Reply #15 on: August 01, 2008, 02:15:18 am »
I've heard that the 2.0 gasser blocks from the 93 to 95 jetta/golf had oil squirters....can't confirm this but it may be a source for piston squirters....
Reply #16August 01, 2008, 08:44:57 am
jackbombay
  • 599
« Reply #16 on: August 01, 2008, 08:44:57 am »
If you go to turbobricks.com and look in the performance forum there is a thread title "squiterizational mod" or something like that, a guy there ships around the tools needed to convert a non squirter Volvo gasser block into a squirter. I'm not totally familiar with how the squirters are set up in the VW TD, but it might be easier to put together a kit like the one on Turbobricks.
Edit- Link to thread in question ---> http://forums.turbobricks.com/showthread.php?t=115422
Reply #17August 01, 2008, 09:08:04 am
myke_w
  • 1099
Re: squirter source....??
« Reply #17 on: August 01, 2008, 09:08:04 am »
Quote from: "jimbote"
That is true. I think all aba motors and all 16v motors have them.
Reply #18August 01, 2008, 09:09:24 am
myke_w
  • 1099
« Reply #18 on: August 01, 2008, 09:09:24 am »
Quote from: "jackbombay"
I've seen that, but I was trying for OE style squirters and the OE face cut angle...  They are using a newer style squirter with banjo bolts... I'd prefer to retain the original design.
Reply #19August 01, 2008, 09:13:34 am
VW_Commuter
  • 355
« Reply #19 on: August 01, 2008, 09:13:34 am »
Quote from: "myke_w"
I previously had an '88 Scirocco 16V and I know the 1.8L 16V motors had them.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #20August 02, 2008, 06:02:06 am
FWD.MOTION
  • 170
im in
« Reply #20 on: August 02, 2008, 06:02:06 am »
I have a 1.5L N/A that I would be interested in getting this done to...what's the final verdict and when to send>?
Im in
BASELYNE
Reply #21August 05, 2008, 06:41:47 am
myke_w
  • 1099
« Reply #21 on: August 05, 2008, 06:41:47 am »
I am still in the planning phase of this. I need to figure out what's the most economical and desirable way to do this.
I guess I'm open to modding blocks to use this kind of squirter, it would be cheaper, but it's not like stock. No sure if anybody cares? Any body feel strongly either way?
Reply #22August 05, 2008, 06:53:06 am
myke_w
  • 1099
« Reply #22 on: August 05, 2008, 06:53:06 am »
Quote from: "Kudagra"
Is there any way to have the squirters squirt MORE to help keep the pistons cooler?
I'm not sure, I'd guess a squirter with a bigger ball and passage would do it. You may want a high volume oil pump at that point to avoid losing too much pressure, an oil pressure gauge would be a must IMO. IIRC the squirters are open at 20psi +. Perhaps I can find a bigger squirter that is a banjo mount and work on that design?
Reply #23August 05, 2008, 07:36:55 am
« Reply #23 on: August 05, 2008, 07:36:55 am »
I don't see a problem with this design Myke.
As a matter a fact i like the idea that it looks simple thus keeping the cost down.
Reply #24August 07, 2008, 07:36:01 pm
FWD.MOTION
  • 170
« Reply #24 on: August 07, 2008, 07:36:01 pm »
if someone was to send you a block like that and get you to add squirters there like that one in the photo what kinda labour are you looking for?
shippings going to be a botch
BASELYNE
