Author Topic: Crank Bolt 1.6td and early TDI part # are the same.  (Read 6645 times)
July 24, 2008, 09:39:06 am
subsonic
  • 1836
« on: July 24, 2008, 09:39:06 am »
Just got off th phone with the dealer.  He confirmed that the crank bolt part number for a 1.6TD was the same part number for the crank bolt on early 1.9TDI's.  Will post the part number when I go pick it up on monday.  Might make finding 1.6 crank bolts a bit easier now.
jim
Reply #1August 11, 2008, 10:11:27 am
subsonic
  • 1836
« Reply #1 on: August 11, 2008, 10:11:27 am »
Sorry for the delay.
Part number # N-905-771-01
Cost from dealer 2.70
It also has the 12 point head vs the 6 point.
Reply #2July 21, 2010, 03:56:52 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
Re: Crank Bolt 1.6td and early TDI part # are the same.
« Reply #2 on: July 21, 2010, 03:56:52 pm »
Is this the bolt that holds on the timing gear?
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #3July 23, 2010, 09:02:54 am
« Reply #3 on: July 23, 2010, 09:02:54 am »
yes. bolt that holds timing sprocket to crank shaft nose.
