engine cuts out at high revs
Topic: engine cuts out at high revs (Read 4107 times)
July 21, 2008, 09:33:34 am
MouseGTD
July 21, 2008, 09:33:34 am »
i have a 91 1.6 GTD, not only is it pritty smoky but the engine cuts out at around 4k rpm and don't fire up again till the revs drop back down to about 1k. if i keep the accelerator to the floor it just revs and drops, revs and drops, revs and drops...
has any one had any thing like this happen or have any idea of what it could be?
cheers for any help
July 21, 2008, 09:55:45 am
burnt_servo
July 21, 2008, 09:55:45 am »
my guess is , you have found the govenor ...
1990 jetta , tweaked pump , tweaked turbo , ported head 2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
July 21, 2008, 10:03:24 am
July 21, 2008, 10:03:24 am »
Or found the clogged fuel filter.
July 21, 2008, 10:20:43 am
MouseGTD
July 21, 2008, 10:20:43 am »
i can't see it being the governor, the bloke that was trying to MOT it couldn't do the emission test due to it not holding the revs, so i'm guessing its not normal.
the fuel filter sounds like it could be it as the MOT tester said he thought it was a problem with the diesel system of some kind. is there any way of cleaning the filter or is it just a case of buying a new one?
July 21, 2008, 10:34:44 am
gigaz2
July 21, 2008, 10:34:44 am »
inexpensive and not cleanable anyway.
July 21, 2008, 11:38:40 am
July 21, 2008, 11:38:40 am »
yea just change it. :wink:
July 21, 2008, 11:48:07 am
burnt_servo
July 21, 2008, 11:48:07 am »
yep you guys are right .... i got to lay off them paint thinners first thing in the morning
but i'll add this , the pick up screen in the fuel tank maybe plugged too .....
or the injection pump could be starting to get weak , and now needs a lift pump to help it out ...
or any combination of the above that may also include a small amount of air being sucked into the injection pump through the joints of the rubber to clear fuel line .
July 21, 2008, 04:36:35 pm
LoneWolf
July 21, 2008, 04:36:35 pm »
Maybe the car wanted to be a petrol?
July 22, 2008, 03:57:43 am
MouseGTD
July 22, 2008, 03:57:43 am »
Quote from: "LoneWolf"
i've just spent the last 7-8 weeks converting it in to a diesel, theres no way i'm going though all that to turn it back lol
cheers for the advice lads, i'll change the filter first and see how it is, if that don't sort it i'll work my way back though the fuel system.
July 22, 2008, 10:52:21 am
LoneWolf
July 22, 2008, 10:52:21 am »
Bloody Shabs, your not the DarkHorse you think you are
July 22, 2008, 11:26:52 am
MouseGTD
July 22, 2008, 11:26:52 am »
busted y00!, thought i could slide in under the radar lol
update...
i've fitted a new filter but now i can't bleed the fuel system through, when i loosen the nut on the top of the injectors off i get diesel spitting out and it will fire up and run then cut out and the fuel pipes stay empty. it weren't this hard to bleed through the last time, any body got any ideas on this? or am i doing some thing wrong? lol
Reply #11
July 22, 2008, 12:47:52 pm
Torchd
Reply #11 on:
July 22, 2008, 12:47:52 pm »
You dont need to bleed these engines after fuel filter change... just crank them for some time and and they start or u can fill the filter with diesel b4 installing so that you dont have to crank for so long!
Reply #12
July 23, 2008, 01:55:37 pm
MouseGTD
Reply #12 on:
July 23, 2008, 01:55:37 pm »
sorted it, after stripping most of the fuel system and still not sorting it i found a loose wire on the fuel pump which sorted it.
now the clutch has gone on it.
