Author Topic: Glow Shift EGT hookup  (Read 9118 times)
July 20, 2008, 04:28:00 pm
Rat407
  • 289
« on: July 20, 2008, 04:28:00 pm »
Ok I did a search but couldn't find anything.  I hooked up my new Glow Shift EGT gage per the instructions, Pink wire to pink temp probe wire, Blue wire to blue temp probe wire, black to ground, red to a switched 12 volts, I used a connection at the fuse block for that, it turns on when I turn the key on. and the yellow wire to a constant power, which I used the cigarette lighter power wire for that.
Here is the problem, when I turn the key on it pegs out to max EGT. So whats up with that?
Thanks.
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #1July 20, 2008, 05:34:15 pm
gigaz2
  • 626
Re: Glow Shift EGT hookup
« Reply #1 on: July 20, 2008, 05:34:15 pm »
Quote from: "Rat407"
Ok I did a search but couldn't find anything.  I hooked up my new Glow Shift EGT gage per the instructions, Pink wire to pink temp probe wire, Blue wire to blue temp probe wire, black to ground, red to a switched 12 volts, I used a connection at the fuse block for that, it turns on when I turn the key on. and the yellow wire to a constant ground, which I used the cigarette lighter power wire for that.
Thanks.
that can't be right
try to contact the manufacturer for advice, they can help you better.
Reply #2July 20, 2008, 07:40:15 pm
Turbinepowered
  • 1206
« Reply #2 on: July 20, 2008, 07:40:15 pm »
Yellow wire for a constant ground? The Cigarette lighter wire isn't a ground, that's a constant 12v supply.
I'm guessing you have a temperature compensated EGT gauge. Check that you have a solid ground connection, good clean contact.
Which connection at the fuse block did you use for your switched 12v? What terminal number, car model and year?
Reply #3July 20, 2008, 08:09:08 pm
Darkness_is_spreading
  • 288
« Reply #3 on: July 20, 2008, 08:09:08 pm »
yeah you might have shorted out your EGT gauge.  The red is probably switched 12V ground for the Illuminations and the yellow is for constant 12 V..  Just look at the instructions,  the egt gauge is essentially a thermal resistor and will have a high resistance when hot and conduct less current and at startup the egt would be cool and the temp would rise the current would be high initially and then drop.....
This is the same principle in conductors over large spans, you run a 3 phase   3/0 gauge wire that can handle say 100 amps (primary 27 600V)line to neutral (Wye system).  If it was really hot out the current would sag and you wold have phase imbalances and your lights would dim (Brownout).
So essentially check your wiring
92 Jetta 1.6 T (Sleepin)
Reply #4July 21, 2008, 01:37:51 am
Rat407
  • 289
« Reply #4 on: July 21, 2008, 01:37:51 am »
I fixed my post, I meant to say the Yellow wire for constant power which I hooked up to the cig lighter.
1991 Jetta  ECO TD
Reply #5July 21, 2008, 05:57:51 am
saurkraut
  • 904
« Reply #5 on: July 21, 2008, 05:57:51 am »
If your cigarette lighter is powered without the key in the ignition, you may run the battery down if you park it for a few days.
There are switched 12 V sources on the back of the fuse box.  Get a simple multimeter, or a test light and find them.
Worst case, you can use the injection pump stop plunger wire for power as that is switched.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #6July 21, 2008, 06:29:38 am
« Reply #6 on: July 21, 2008, 06:29:38 am »
It should peg to max, then go back down to whatever the current temp is. If it stays pegged, it is bad and should be returned. It is supposed to be a self test.
Reply #7July 21, 2008, 08:59:44 am
« Reply #7 on: July 21, 2008, 08:59:44 am »
Quote from: "saurkraut"
... although not fused... so caution is warranted !!
On MK2s there's a big fused heavy wire that feeds the rear window defogger switch and another that feeds the defrost fan... lots of power and it's close to where most people install their accessories.
Having said that, I wouldn't use it for voltage-sensitive gauges like oil temp and pressure... depending on your grounds the dip in voltage when you turn on the rear defogger or fan could impact the reading.
My cars all have pimped glowplug wiring so a very direct and fused line to the battery for all add-ons and do-hickies.
Reply #8July 21, 2008, 05:32:58 pm
KTZed
  • 170
« Reply #8 on: July 21, 2008, 05:32:58 pm »
Heres how I wired mine. The wires connected to the fuse panel were run to a distribution block and then to 3 glowshift gauges (boost, egt, and oil pressure) as they all needed switched and constant power.
I used the conveniently located holes in the fuse panel to tap into the switched and constant 12v. One side of the 5A fuse is plugged into the panel and the other side is attached to the gauge wire via a female spade connector run through the backside of the panel.
EDIT: Also note that the glowshift wiring is switched 12V = red, constant 12V = yellow, whereas the VW wiring is the opposite (on the wires behind the fuse panel of my car anyways).
I will say that I had a VERY strange electrical gremlin acting on my EGT gauge when I first hooked it up but it was the result of me trying to run an aircraft spruce probe with the glowshift gauge. As soon as I switched back to using the glowshift probe, the problem disappeared.
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
Reply #9July 21, 2008, 06:37:42 pm
Rat407
  • 289
« Reply #9 on: July 21, 2008, 06:37:42 pm »
I got it to work. Turns out the ground was not good. I took it straight to the Neg terminal on the battery and it is working. It sure does react fast too. Now to be careful. I took it up to 1200 in no time.
1991 Jetta  ECO TD
Reply #10July 21, 2008, 08:48:01 pm
« Reply #10 on: July 21, 2008, 08:48:01 pm »
Yup, once you have an EGT and see how easy it is to get in the red you are soon recommending "don't leave home without it".
Reply #11July 22, 2008, 09:26:47 am
saurkraut
  • 904
« Reply #11 on: July 22, 2008, 09:26:47 am »
Quote from: "Vincent Waldon"
yah, I'm not a big fan of the using the stop solinoid either.  Haven't used it my self.  I think Roger Brown recomends powering his opticle tachometer drive from the stop solinoid though.
But constant power to anything but the clock kind of bugs me, and there is at least one switched 12V terminal on the back of the fuse box that is wide open for use.
That's what I'm useing to power my EGT contraptions on both of my Rabbits.  Works good, lastest long time.
I haven't looked in the Bently, but I wouldn't be surprised to see the terminal labled 'accessory'.
And if you want to see a fast EGT reading, get the Aircraft Spruce thermocouple.  It moves as fast as the boost gauge.  And you will be surprised how high the EGT actually gets, as the slower thermocouples will never show a max temp because they are so slow.
On my '79 1.6TD, I had been running the VDO thermocouple and gauge, and hadn't seen anything much over 1,250°.
A few months ago, I swapped in the Spruce thermocouple and discovered that I was getting up to 1400° max EGT under the same conditions that the VDO thermocouple showed 1,250° and climing.
Typically I was going too fast and had to let off befor the VDO thermocouple had reached a peak temp.  But the Spruce thermocouple is so fast that it shows more of a 'real time' reading.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
