Author Topic: Cummings VE Pump to a VW VE Pump???  (Read 2128 times)
July 20, 2008, 04:53:47 am
chrisrandle1
  • 32
« on: July 20, 2008, 04:53:47 am »
I was wondering if anyone knew if there would be any gains, or if it was even possible to convert a cummings ve pump to a vw pump.  It seems to me that if you were to change the rotor and head, it might work.
Just an idea.
What do you guys think?
-Chris
1992 EcoDiesel - Soon to have P n P Head, T3 Turbo and more!!!
Reply #1July 20, 2008, 04:57:06 am
dillenger1
  • 777
« Reply #1 on: July 20, 2008, 04:57:06 am »
the governor spring is different.The shaft is larger to.I believe the lda will switch over though as long as you remove the gov assedmbly.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2July 20, 2008, 05:00:30 am
chrisrandle1
  • 32
« Reply #2 on: July 20, 2008, 05:00:30 am »
Possible Gains?
Reply #3July 20, 2008, 12:11:23 pm
chrisrandle1
  • 32
« Reply #3 on: July 20, 2008, 12:11:23 pm »
I also noticed that they were a bit more expensive...I guess I will forget that idea.
Thanks for the replys
-Chris
Reply #4July 20, 2008, 09:29:08 pm
  • 2932
« Reply #4 on: July 20, 2008, 09:29:08 pm »
the control collar lever assembly has the wrong offset
 Will this keep me from sticking the 12mm head on the VW pump body?
