Author Topic: engine oil priming after rebuild  (Read 8741 times)
Reply #15July 24, 2008, 06:22:24 am
autoholic
« Reply #15 on: July 24, 2008, 06:22:24 am »
Ok, Gasket #3 going in tonight. #2 got dinged as I lowered the head on last time, it was pretty heavy/awkward installing it with the manifolds on by myself and the Sami is pretty high. this time I'll use the chain fall hoist that is right above the engine (and has been the whole time)
I'm using new bolts too.
I'm getting sick of this project (but not as sick of it as my wife)
Reply #16July 28, 2008, 05:08:15 am
autoholic
« Reply #16 on: July 28, 2008, 05:08:15 am »
Finally started it last night, runs great!
I still have lots of wiring to do, exhaust, etc, but I did take it for a spin up the road and it felt good, lots of torque!
I am using a Geo tracker gear reduction starter which turns it over better then expected (the stock sami starter was very weak)
The Radiator is from a Rabbit, with 2 10" electric fans, seems to work well.
The only problem I am having is that two of my injectors seem to leak a tiny bit, no big deal.
Oil Psi is good and coolant seemed to flow like it should.
I'll post some pics when I get a chance.
 :D
Reply #17July 28, 2008, 07:06:57 am
riddleyo
  • 130
« Reply #17 on: July 28, 2008, 07:06:57 am »
congrats on getting it running man.
Yea, those upside-down headgasket pictures are from my car LOL. Glad to see I'm the example of what NOT to do.  :)
It is very easy to install the headgasket upside down! Good thing the experts on this forum have a sharp eye though.
1985 VW Golf Diesel 1.6L N/A
My Build Thread: http://www.vwdiesel.net/forum/index.php?topic=14607.0
Reply #18July 28, 2008, 07:28:34 am
« Reply #18 on: July 28, 2008, 07:28:34 am »
I'll second Vince here.
You found it BEFORE you attempted a start up. Kudos Mr.
Reply #19July 28, 2008, 07:05:42 pm
CoolAirVw
  • 175
« Reply #19 on: July 28, 2008, 07:05:42 pm »
Quote from: "Vincent Waldon"
Nah.... like I said... you're brilliant,  because you took the time to check for oil pressure *before* firing it up !   :wink:
I also think your brilliant for catching the mistake before you fired it up!
Excellent double checks make for excellent work!
You get a thumbs up!  No make that 2 thumbs up!
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #20July 28, 2008, 07:24:02 pm
Turbinepowered
  • 1206
« Reply #20 on: July 28, 2008, 07:24:02 pm »
Quote from: "CoolAirVw"
Siskel! Ebert! I found them, guys, hey, I found them! :D
Reply #21July 29, 2008, 04:40:10 am
Turbinepowered
  • 1206
« Reply #21 on: July 29, 2008, 04:40:10 am »
Quote from: "libbybapa"
Dude, that's Roeper...
Andrew
I still remember Siskel, alas.
Reply #22July 29, 2008, 08:22:05 pm
Caddyman
  • 7
« Reply #22 on: July 29, 2008, 08:22:05 pm »
Quote from: "autoholic"
 :D
Where are the injectors leaking? FYI, if they are leaking around the outside diameter of the injector body you will have to lap (sand and wet sand) the sealing / mating surface (the surface that touches the heat shield) and get new heat shields.
Where did you get your 1.9 cam plate?
Reply #23July 30, 2008, 05:30:04 am
autoholic
« Reply #23 on: July 30, 2008, 05:30:04 am »
Thanks folks,
I hope to have some time this weekend to wrap this thing up.
While I'll always wish for a Rabbit again, I gotta say, this Samurai will be a blast and will be practical for the terrible roads around here (bad mud season, snow, etc)
I got the camplate from Volkswa parts, other stuff from there as well.
Yea, I should have lapped those pieces better, I think I'll do another set to have on hand.
This thing does some nice little donuts with that rear locker!
