garret turbo questions and pyrometer sensor mount-1.6 td
Topic: garret turbo questions and pyrometer sensor mount-1.6 td (Read 6217 times)
May 17, 2005, 12:47:42 pm
frankentoy
May 17, 2005, 12:47:42 pm »
ive been putting this motor back together and trying to figure a few things out as i go as it wasnt together when i bought. this is an 87 jetta 1.6 td.
first is the hole on the exhaust manifold shown, the correct spot for a egt gauge sensor? if not would be ok or do i want it down the exhaust somewhere?
next the 2 female threaded holes on the waistegate...the large one i believe is for the waistegate..excess boost..and what is the smaller one for?
and last for now..what am i supposed to do with the hole on the bottom of the front impellar housing. it goes right through and out just in front of the impellar? i think ive seen a jet of some sort on another similar turbo somwhere but i dont think this one had one.
thank you, jason
ohiopowdercoating.com
May 17, 2005, 01:00:10 pm
Moderator
May 17, 2005, 01:00:10 pm »
Here's a picture
showing where my EGT probe is mounted.
I would prefer the probe to be as close as possible to the centre of the exhaust stream coming from all cylinders.
http://www.tunezilla.com
93 Eurovan AHU TDI
97 Golf Variant Syncro 1.9L 1Z TDI -
sold and missed
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
May 17, 2005, 01:16:52 pm
frankentoy
May 17, 2005, 01:16:52 pm »
thanks devast8r. i really dont want to attempt what you guys did and dont want to pull it all apart again. any idea about the other things i menetioned. and the next time you hit a yard can you take a look for a few little things for me? not too many td in junk yards around here. thanks
May 17, 2005, 08:58:31 pm
MK3 GTD
User+
May 17, 2005, 08:58:31 pm »
IIRC the hole in the turbo inlet should have a bung there that connects to the smaller wastegate port and the boost port connects to the port closer to the outlet of the compressor housing
1996 Golf 1.9TD
1984 Rabbit 1.6TD
1987 Jetta Coupe 1.6D
May 18, 2005, 11:25:55 am
frankentoy
May 18, 2005, 11:25:55 am »
can i see a picture if your bung? :?
May 18, 2005, 11:32:03 am
fspGTD
May 18, 2005, 11:32:03 am »
That smaller hose connection is to evacuate any oil that might accumulate in the wastegate diaphgram chamber. There is a quite long and slender brass fitting on my Garrett TA0304B (1.6lTD application) that threads into the hole in the bottom of the compressor inlet and has a nipple that the rubber hose slips over. Inside the fitting there is a small orifice. I would guess that this piece is paricular to this turbo model or manufacturer.
It looks like from your picture that it is missing. I would ask whoever you got the turbo from, or whoever "rebuilt" it, what happened to its missing pieces. Unfortunately, spare parts for the Garrett TA0304B seem to be "off limits" for most Garrett turbo parts suppliers... they want you to buy a complete new or rebuilt one through the VW dealer it seems! :?
By the way, for my pre-turbine pyrometer in the Garrett 1.6lTD turbo, I drilled and tapped the turbine housing right into the main turbine inlet port, with the wires for the thermocouple extending downwards. That is another option besides the exhaust manifold, although you need to be precise where you put the hole and the direction as there is not a lot of room there. I found also that the cast iron of the Garrett TA0304B had some very hard spots that made the drill want to wander around when it hit them, so be extra careful if you go this route.
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
May 18, 2005, 12:00:32 pm
fspGTD
May 18, 2005, 12:00:32 pm »
I uploaded an old pic I found of the turbine-housing pre-turbine pyrometer for you... here you go:
Jake Russell
Dieselicious
May 18, 2005, 01:30:37 pm
frankentoy
May 18, 2005, 01:30:37 pm »
thanks jake. i rbuilt the turbo myself and it didnt have those parts when i tore it apart. so if i wanted to make my own replacements. i need to understand what they are for. you said the small hole on the waiste gate is for excess oil in the waistgate. so..does the hose/line running from under the comp housings blow air into that small hole on th waistegate to purge the oil out back? you would think it would draw oil out that hole towards the impellar, but why?or what is going on there? thanks for your explaination.
May 18, 2005, 05:52:46 pm
fspGTD
May 18, 2005, 05:52:46 pm »
The second smaller line connects to the compressor inlet to keep oil from acculumating inside the wastegate can. So yes, there is a small flow of air from inside the wastegate can through that line into the compressor inlet, and this flow is there to keep excess oil out of the wastegate can.
Jake Russell
Dieselicious
May 18, 2005, 06:22:36 pm
frankentoy
May 18, 2005, 06:22:36 pm »
thanks jake.
