Author Topic: Clear Diesel Fuel lines  (Read 11521 times)
July 16, 2008, 03:01:53 pm
kane66
  • 131
« on: July 16, 2008, 03:01:53 pm »
I'm trying to find some clear fuel lines so I can test the pump in my 1.6.... but none of the autopart stores stock it. Is there something else I can use. I would prefer something that will hold up over time as I plan on using them in the car permanent after the test.
1985 Jetta WBE
Reply #1July 16, 2008, 03:11:17 pm
« Reply #1 on: July 16, 2008, 03:11:17 pm »
I'm using clear (ish) Blue line I bought from the motorcycle shop and I'm using what the hose place called "Ether tubing" for the returns off the injectors. That stuff is clear and has been there for a bit over 1000 miles now.
Reply #2July 16, 2008, 06:46:03 pm
shegel
  • 312
« Reply #2 on: July 16, 2008, 06:46:03 pm »
bio safe?
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #3July 16, 2008, 06:57:09 pm
Rat407
  • 289
« Reply #3 on: July 16, 2008, 06:57:09 pm »
Quote from: "shegel"
bio safe?
Yes, you can get the urathane tube at any motorcycle shop. It comes in Blue and yellow, works great and stays soft. I have had mine on my 91 ECO for over three years now and 40k miles and it is just like the day I put it on.  I use, I think 3/16 semi truck air brake line for the injector cross over lines. It works great as well. Both are BIO safe.
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #4July 16, 2008, 09:15:55 pm
« Reply #4 on: July 16, 2008, 09:15:55 pm »
Quote from: "Rat407"
bio safe?
I didn't think of the air brake lines...
I used 1/8" clear for the injectors. I was looking tonight and it looks like a couple may be weeping. I heated the ends when I put them on and I think they stayed stretched out due to the heat, there are a couple that I didn't heat just to try and those are not leaking.
I'm going to replace the leaking ones this weekend and not heat the ends.
Also when I say leak it as I said earlier, more of a weep. the injector is wet around the nipple but it's not leaking enough to actually run down the injector the base's are dry.
Reply #5July 17, 2008, 05:59:10 am
saurkraut
  • 904
« Reply #5 on: July 17, 2008, 05:59:10 am »
The oem stuff is nylon. I recall reading somewhere that diesel will attack the Poly stuff.
You can order it directly from McMaster Carr. Its rock hard, just like the original stuff.
Here is the schmidt:
Part No. 8359K15
25' length: $12.50
Description: High-Strength Clear Nylon
Tubing .242" ID
5/16" OD
.035" Wall Thickness
You have to warm the ends up to get them to slide over the hose barbs. Heat the ends till they just start to get plyable, then firmly ram the hose onto the barbs.
Its allot easier if you take the barb nerds off the pump and filter housing while your installing the new fuel line on them.
No leaks yet after 3 months.  Here it is on my 1.6TD:
Here is some small diameter nylon that might work for the return lines. Might be a little stiff though. Its dirt cheap, so trying it won't be too expensive. Viton might be a better choise for the return lines.
Part Number: 8365K22
1-99 Ft. $0.61 per Ft.
100 or more $0.45 per Ft.
Type: High-Strength Clear Nylon Tubing
Material: Nylon 6
Shape: Single Line
Outside Dia.: 5 mm
Inside Dia.: 3 mm
Wall Thickness: 1 mm
Available Lengths: 25, 50, and 100 feet
Reinforcement: Unreinforced
Color: Clear
Maximum Pressure: 380 psi @ 75º F
Operating Temperature Range: -40º to +212º F
Bend Radius: 51 mm
Durometer: 80D (Hard)
Tensile Strength: 10,875 psi
For Use With: Air, Food, Fuel, Water
Sterilize With: Gas
Specifications Met: United States Food and Drug Administration (FDA)
FDA Specification: CFR21 177.1500
Compatible Fittings: Compression
Chemical Compatibility Link: 5112KAC
http://www.mcmaster.com/
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #6July 18, 2008, 03:31:35 pm
diffdude
  • 39
« Reply #6 on: July 18, 2008, 03:31:35 pm »
I got mine from my local lawn mover shop. It has a yellow tint.
81 caddy 1.6 td, 2.5" turbo back, snow performance water/meth injection, and all the other usual mods.
