Author Topic: TD 1.9 AIRBOX  (Read 4648 times)
July 13, 2008, 08:47:05 pm
GEE-BEE
  • 1604
TD 1.9 AIRBOX
« on: July 13, 2008, 08:47:05 pm »
Doing a swap in a mk1 caddy
looking for a AIRFILER ASY BOX to fit a 1.9 TD AAZ
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1July 13, 2008, 10:25:21 pm
Quantum TD
  • 1195
TD 1.9 AIRBOX
« Reply #1 on: July 13, 2008, 10:25:21 pm »
I'm pretty sure it's the same (or similar enough) to the MK3 2.0 gasser airbox. It mounts the same, and I think it has the same dimensions. The obvious difference is that the gasser has a MAF. I'm pretty sure the ALH (1997-1998 TDI Jetta and Golf) use the same box too.
Reply #2July 13, 2008, 11:18:06 pm
blkboostedtruck
  • 1535
TD 1.9 AIRBOX
« Reply #2 on: July 13, 2008, 11:18:06 pm »
or you can use a K&N filter
i use one on my caddy that has a AAZ in it!
i have the part # for it! let me know if you want it?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3July 14, 2008, 05:46:43 pm
GEE-BEE
  • 1604
K & N assy
« Reply #3 on: July 14, 2008, 05:46:43 pm »
Please advise the part #
Regards Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #4July 15, 2008, 04:17:15 am
stewardc
TD 1.9 AIRBOX
« Reply #4 on: July 15, 2008, 04:17:15 am »
My box is off a 1.6TD Mk 1 Jetta. Use whatever fits in the hole.
Reply #5July 15, 2008, 01:13:28 pm
blkboostedtruck
  • 1535
Re: K & N assy
« Reply #5 on: July 15, 2008, 01:13:28 pm »
Quote from: "GEE-BEE"
Regards Gee-Bee
 part# for K&N  air filter             RF-1025
and that will work for both AAZ and 1.6TD intake hoses
Duane
'66 variant 1500S
