Author Topic: Injector Servicing Kit  (Read 4134 times)
July 10, 2008, 09:10:36 am
VW_Commuter
  • 355
« on: July 10, 2008, 09:10:36 am »
I'm drooling over this kit over at MercedesSource.com.  For $258 I'm thinking it might be worth it since it includes a shim kit to set break pressure and the pressure gauge is a 0-3000psi.  If I were to get it I might replace the gauge with one with a larger face and a mirror strip so you can read the gauge more accurately.
Greg
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #1July 10, 2008, 09:32:58 am
Possum79
  • 276
    • http://www.poscarclub.com
« Reply #1 on: July 10, 2008, 09:32:58 am »
Im interested in the shim kits they have. My only question is are they the same a vw shims?
1979 VW Rabbit Diesel L
Reply #2July 10, 2008, 09:42:18 am
VW_Commuter
  • 355
« Reply #2 on: July 10, 2008, 09:42:18 am »
I'm pretty sure that the injectors were the same size as everyone is talking about using Merc 300d nozzles in our injectors.  I've asked the question on the mercedessource.com website on whether or not these shims will fit our injectors and will let everyone know what I find out.
Greg
Reply #3July 10, 2008, 10:15:25 am
« Reply #3 on: July 10, 2008, 10:15:25 am »
That actually looks like a pretty good deal.!!
Reply #4July 10, 2008, 10:44:07 am
Possum79
  • 276
« Reply #4 on: July 10, 2008, 10:44:07 am »
Well I did some digging because I knew someone had posted the O.D. of the single spring shims.
In the group buy thread Duane wrote
Quote from: "blkboostedtruck"
the single spring shim i have some in my collection now and the O.D. is 11.44 to 11.42mm and the center hole I.D. is from 3.02mm to 5.05mm depending on who made the shim i guess as long as there is a hole in the center it will work!
The merc shop says the O.D. of the shim is approx 11.5mm
I recon that would be real close to identical to what is needed.
Reply #5July 10, 2008, 05:00:00 pm
VW_Commuter
  • 355
« Reply #5 on: July 10, 2008, 05:00:00 pm »
I just got an email reply from Kaia at mercedesservice.com and she stated that "The OD on all of our shims is 11.5 mm" and "the ID varies from shim to shim".  That information correlates with Possum79's info from blkboostedtruck.  One of the techs at H&H Diesel Service in Auburn, WA also confirmed that the shim size is the same between the Mercedes and VW IDI injectors.  This is great news, now we have a readily accessible supply of shims so we can rebuild our own injectors and set the break pressures.
Greg
Greg
Reply #6July 10, 2008, 06:10:54 pm
« Reply #6 on: July 10, 2008, 06:10:54 pm »
this is a pretty sweet kit...  but you'd have to do about 12 injectors to make the kit worthwhile.  but even just being able to test spray patterns is pretty sweet!
Reply #7July 10, 2008, 08:56:55 pm
VW_Commuter
  • 355
« Reply #7 on: July 10, 2008, 08:56:55 pm »
I'm thinking about getting it so I can do my own injectors and know what kind of job went in to them.  I would also like to test Merc vs OEM VW vs GTD nozzles at different pressures to see what nozzle and pressure will give us the best spray pattern.  I was also thinking of using my Nikon DSLR and getting pictures of the different spray patterns to post for others to see.  Besides, if I get this kit I don't have to run down all of the different stuff that's in the kit separately.  I'm real big on saving myself time and aggravation.   :D
Greg
Reply #8July 10, 2008, 09:55:40 pm
blkboostedtruck
  • 1535
« Reply #8 on: July 10, 2008, 09:55:40 pm »
well guys i'll step in and tell you what i think!
looks to be a nice starter kit! those are the right shims and will work!
MB&VW are the same except late model dual stage injectors 1.9
says her you do have to make your own adapter for your injectors
when VW put thier shims in they have 1of the right size because everyone i measured came in .001 of whatever size that calibrated it to exact! so they must of had a board loaded with 1000's of sizes? you can use more than i shim when calibrating! but as small as that set is you may only get 1to 2 sets shimmed ?  no biggie as you know i know where to get shims!
and having a bigger selection like i have is easier IMHO!
well one other thing is the gage! i hear bigger is better! thats what inj. repair shops say! even tho i have a professional poptester! it is an older style with a smaller gage! i wish it was much bigger or had something that marked it's hight that it reaches!
but i give it a thumbs up for creativity! i have double that invested in mine!
but if that was around i would of bought that instead!
so somebody get it and report on how it works?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #9July 11, 2008, 12:23:40 pm
foxracer1
  • 991
« Reply #9 on: July 11, 2008, 12:23:40 pm »
I told a friend about it and we are thinking of buying one together. Between us we have several diesels.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #10July 11, 2008, 12:47:57 pm
« Reply #10 on: July 11, 2008, 12:47:57 pm »
Excellent plan... almost a no-brainer split amongst friends... and if you're like me once word spreads that you have a pop-tester you'll...er... make *new* friends all of a sudden. ;-)
Reply #11July 11, 2008, 01:39:46 pm
VW_Commuter
  • 355
« Reply #11 on: July 11, 2008, 01:39:46 pm »
Quote from: "Vincent Waldon"
LOL
Greg
