Author Topic: hole at top of transmission  (Read 4701 times)
July 06, 2008, 12:56:13 pm
danwithagolf
  • 43
« on: July 06, 2008, 12:56:13 pm »
i have a 87 golf n/a 5speed today i was spraying down the motor (it was real dusty) and i realized that there is a hold at the top of the transmission if water got in there could that damage my trans? i know that hole is not where you add fluid but it seems to be open im not to sure what its even for?
87 Golf n/a
Reply #1July 06, 2008, 01:31:41 pm
Hammy
  • 169
« Reply #1 on: July 06, 2008, 01:31:41 pm »
Dan:
 That hole is for lining up the crankshaft timing mark. There should be a little pointer mark on the aluminum case inside that hole (looking toward the engine). Inside of that case will be your flywheel/clutch assembly, and on the outside would be an alignment mark, that you would align to the pointer mark inside of that hole. It is used for timing timing camshaft, injection pump, or when changing the timing belt. If you look closely, you will see that inside the hole, there are threads. There is supposed to be a plastic threading plug to keep crap from getting in there and possibly contaminating your clutch. I would suggest going to the wreckers and getting one.
 I hope that helps, if I missed anything, I am sure someone will add to this.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #2July 06, 2008, 05:11:07 pm
« Reply #2 on: July 06, 2008, 05:11:07 pm »
it's a 27mm allen head style plug that takes a lot of effort to remove. I personally don't have one on my car because I had to chisel it out
Reply #3July 06, 2008, 06:53:26 pm
danwithagolf
  • 43
« Reply #3 on: July 06, 2008, 06:53:26 pm »
thanks a lot guys i got not even a tea spoon of water i took it for a drive it feels fine i just wanted to make sure mine dose have the plastic cap just a hole in the middle of it but it seems fine thanks again dan
87 Golf n/a
Reply #4July 06, 2008, 10:45:35 pm
  • 2932
« Reply #4 on: July 06, 2008, 10:45:35 pm »
There's a plastic plug for that hole in the middle.
 A little water isn't going to hurt it. Might rinse it out a little.
 It'll all just drain out the bottom.
Reply #5July 06, 2008, 11:11:24 pm
danwithagolf
  • 43
« Reply #5 on: July 06, 2008, 11:11:24 pm »
ya i guess im missing that plug all have to go to the wreckers and find one thanks guys
87 Golf n/a
