Author Topic: Glow plug issues  (Read 5214 times)
June 25, 2008, 06:20:38 pm
webman
  • 14
Glow plug issues
« on: June 25, 2008, 06:20:38 pm »
I recently picked up a 91 Jetta that is having problems with the glow plugs.  I am having two problems, and they are likley related.
1) The glow plug indicator on the dash does not come on, but I believe the LED is good.  I did a test between L ad 85 on the glow plug connector, but I did not show any voltage.
2) The glow plugs come on and appear to stay on.  I waited 45 sec and there was still power showing at the glow plugs.
I have replaced the relay with a new one, but still have both problems.
Any ideas where I should start looking?  I have tried all the tests in the Bently manual for the glow plugs, but not sure where the problems are.  Also, it mentions a fuse for the indicator, but I don't see one labeled on the fuse panel.
Reply #1June 25, 2008, 07:13:44 pm
Glow plug issues
« Reply #1 on: June 25, 2008, 07:13:44 pm »
I'd suspect the temp sensor myself.
You can jump the glow plug light through the glow plug relay socket.
Reply #2June 25, 2008, 07:30:25 pm
CoolAirVw
  • 175
Glow plug issues
« Reply #2 on: June 25, 2008, 07:30:25 pm »
VWCaddy's page has some of the best info I've seen on how the glow plug system works.
http://www.4crawler.com/Diesel/GlowPlug.shtml
Heres another.
http://www.cs.rochester.edu/u/jag/vw/engine/glowplugs/glowplugs.html
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #3June 25, 2008, 07:42:51 pm
webman
  • 14
Glow plug issues
« Reply #3 on: June 25, 2008, 07:42:51 pm »
Quote from: "burn_your_money"
So do I go from power to the L terminal?
Reply #4June 26, 2008, 04:55:07 am
Reply #5June 26, 2008, 07:57:37 pm
webman
  • 14
Glow plug issues
« Reply #5 on: June 26, 2008, 07:57:37 pm »
Which temp sensor is for the glow plugs?  The one on the top or side?
