Author Topic: 94 Jetta TD - buying advice  (Read 2355 times)
June 24, 2008, 10:17:27 am
Veedubster
  • 4
« on: June 24, 2008, 10:17:27 am »
Hi there,
I have an 81 diesel Caddy that is running good but I would like to replace the engine with a 1.9TD down the road.  A friend at work has a 94 Jetta TD he's selling cheap but there is one concern I have and that is the glowplugs are stuck.  The VW shop he goes to said the head would crack if they attempt to remove / replace the glowplugs?!  Should I be concerned?  If I do buy the Jetta, I'll drive it for a bit but will part it out to fund my Caddy project.
BTW, my Caddy has 288,xxx km on the 1.6 NA whereas the 94 Jetta TD has 320,xxx km.  I might be better off just keeping the 1.6.  :lol:
TIA!
81 Caddy diesel
Reply #1June 24, 2008, 10:24:09 am
« Reply #1 on: June 24, 2008, 10:24:09 am »
Never heard of glowplugs cracking the head. Injectors, yes, but not glowplugs. They would probably be easiest to remove with the engine hot, like removing the injectors.
Reply #2June 24, 2008, 10:36:33 am
Veedubster
  • 4
« Reply #2 on: June 24, 2008, 10:36:33 am »
Quote from: "jimfoo"
Actually he was told the block would crack, not the head which I thought was odd.  I agree, injectors would make more sense.  I'm meeting up with him today to have a thorough look at the car.  If anything, I should have everything I need for my swap.
Thanks!
81 Caddy diesel
Reply #3June 24, 2008, 11:46:45 am
« Reply #3 on: June 24, 2008, 11:46:45 am »
how would the block be cracked when removing the glow plugs?  i would think that the glow plugs themselves would crack before the block... especially since they are in the head  :roll:
best to spray them with some kind of penetrating lube over time and then remove them while its hot like jimfoo said.  if they're in there really good you might have to remove the injection pump.  when installing new ones be sure to put some anti seize on the threads to avoid this problem in the future  :wink:
Reply #4June 24, 2008, 12:25:01 pm
Veedubster
  • 4
« Reply #4 on: June 24, 2008, 12:25:01 pm »
Quote from: "jtanguay"
Yeah, I had my doubts as well when he mentioned the block would crack if the seized glowplugs were removed.  The glowplugs are in the head, so I figure the so called "VW shop" gave him a line.  It's all very comical now that I think of it.  :lol:
Anyway, I'm seeing him in a few minutes.
Thanks!
81 Caddy diesel
Reply #5June 24, 2008, 07:24:15 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: June 24, 2008, 07:24:15 pm »
Dont forget the glowplugs are kinda hollow.
Watch out for head cracking while removing 10mm plugs that are hollow!! LOL! Be careful of the engine block too..
Reply #6June 24, 2008, 10:04:35 pm
Veedubster
  • 4
« Reply #6 on: June 24, 2008, 10:04:35 pm »
Well, I had a good look at the car.  It's definitely not worth his asking price of $2500Cdn with all the rust, dents, bondo...etc.  Even if I did buy it for the engine, the rest would be difficult to part.
What is the going price for a 1.9TD with tranny anyway?  I missed out on a running 1.6TD Rabbit last week for $400.
81 Caddy diesel
Reply #7June 24, 2008, 10:50:47 pm
burnt_servo
  • 278
« Reply #7 on: June 24, 2008, 10:50:47 pm »
Quote from: "Veedubster"
check with the autowreckers  ..... you will find it is about 2500.00 for a running low millage 1.9 td engine in good shape  :)
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
