Author Topic: what is stock k14 exhaust a/r?  (Read 3639 times)
June 20, 2008, 04:28:14 am
zaprzal
  • 160
    • turbodiesel.pl
« on: June 20, 2008, 04:28:14 am »
what is stock k14 exhaust housing a/r?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #1June 21, 2008, 09:32:39 am
« Reply #1 on: June 21, 2008, 09:32:39 am »
I am a turbo noob, but I have read alot about them on this and many other sites. The FAQ here is where I got these links which might help you.
http://vwdiesel.net/phpBB/viewtopic.php?t=7069
http://www.myturbodiesel.com/
Reply #2June 21, 2008, 11:02:09 am
andy2
« Reply #2 on: June 21, 2008, 11:02:09 am »
The k14 from the AAZ says .3  I'm not sur if the 1.6 eco turbo is any different.
Reply #3June 21, 2008, 12:20:29 pm
« Reply #3 on: June 21, 2008, 12:20:29 pm »
it's my understanding that only the cold side is different on the AAZ/eco k14s.
Reply #4June 22, 2008, 04:47:20 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #4 on: June 22, 2008, 04:47:20 am »
and stock k24 is .36?
Reply #5June 22, 2008, 09:55:14 am
andy2
« Reply #5 on: June 22, 2008, 09:55:14 am »
The k14 and k24 both have the same .3 turbine A/R however that is the only common spec between the two housings.The T3 has the .36 A/R.
Reply #6June 22, 2008, 10:16:10 am
andy2
« Reply #6 on: June 22, 2008, 10:16:10 am »
While were on the topic the ko3 reads 3/1 which might mean 3.1 A/R and the T2 reads .35 AR.
Using the turbine A/R to figure out which turbo is bigger/smaller is not the best way of figuring out which 1.6/1.9 turbo is bigger than the other.As you can see all of the 1.6/1.9 turbos have roughly the same turbine A/R and the only huge differences between the turbine sections are the wheel sizes and wheel trim.
