Author Topic: High EGT on my AAZ  (Read 14789 times)
June 19, 2008, 05:03:54 pm
orbitald
  • 53
High EGT on my AAZ
« on: June 19, 2008, 05:03:54 pm »
Questions,
I have an AAZ in my Vanagon Syncro:
- K03 turbo
- 2.5" exhaust
- GTD nozzles
- SAAB blackstone intercooler with 800cfm fan
- EGT sensor pre-turbo
- Boost at about 11psi
- I'm running 235/70/16 with stock gearing
I'm trying to find the right balance of power and low EGTs.
I've rotated the boost pin 1/2 turn and the van has plenty of power now but my EGT temps are climbing over 1250 on longer hills. Will increasing my boost also increase my EGT?
What does rotating the star wheel do?
How do I lower my EGT and keep the power?
Thanks,
D
http://picasaweb.google.com/Orbitald/DieselVanagonStuff/photo#5194145059298034050
Reply #1June 19, 2008, 05:14:54 pm
High EGT on my AAZ
« Reply #1 on: June 19, 2008, 05:14:54 pm »
High EGTs are unburnt fuel. More boost (or a colder charge) lowers EGTs. Reducing backpressure also lowers EGTs. Bad injectors, worn pump, bad timing are also causes of high EGTs
Reply #2June 19, 2008, 05:20:50 pm
High EGT on my AAZ
« Reply #2 on: June 19, 2008, 05:20:50 pm »
you think 1250F is hot??? thats normal... when you hit 1400F come back  :lol:
Reply #3June 19, 2008, 06:00:43 pm
orbitald
  • 53
High EGT on my AAZ
« Reply #3 on: June 19, 2008, 06:00:43 pm »
Thanks Burn - so increasing my boost slightly might actually bring my EGT down a bit which would be nice. My motor only has about 3K miles on it so I don't think its excessively worn but I should check the timing.
I'm guessing it best to check the timing after boost / fuel pin adjustments are made?
jtanguay - since my motor is kinda new I'm trying to stay in a comfort zone; keeping EGTs and boost as low as possible and still make it over the hill doing 55mph which is somewhat of a balancing act with a Syncro Vanagon with big wheels / tires. I think it would actually go up to 1400F but I back off the petal and shift down to 3rd to keep it around 1250F cresting a big hill at around 50mph.
I could also go with a liquid cooled intercooler but thats another bag of money I still waiting to drop from the sky.
Any insight on what the rotating the star wheel does?
D
Reply #4June 19, 2008, 06:06:23 pm
High EGT on my AAZ
« Reply #4 on: June 19, 2008, 06:06:23 pm »
The starwheel decreases fuel with boost if it is screwed up, and increases it if screwed down.
Reply #5June 19, 2008, 06:12:21 pm
orbitald
  • 53
High EGT on my AAZ
« Reply #5 on: June 19, 2008, 06:12:21 pm »
Thanks Jimfoo,
Is there a procedure for setting all the variables so that maximum burn is achieved?
Reply #6June 19, 2008, 06:35:26 pm
High EGT on my AAZ
« Reply #6 on: June 19, 2008, 06:35:26 pm »
Yeah, trial and error unfortunately.
Reply #7June 19, 2008, 08:26:23 pm
vanagonturbo
  • 639
    • Fine Tuning
High EGT on my AAZ
« Reply #7 on: June 19, 2008, 08:26:23 pm »
double your boost.
Here is my setup:
Syncro
225/70/16
final drive ratio 4.86
third gear 1.14
4th gear .77
New AAZ
Non intercooled (for now)
2.5" exh
K03 turbo
fuel screw turned in about two turns
star wheel screwed almost all the way down
1.6td boost pin rotated in the direction of funtime power
vehicle wieght is 5200lbs unladen
I can easily hit 1300 on the freeway during acceleration. I usually keep it around 10-1200. I am at sea level. Mountain pass at a 5% grade will put me in 3rd gear @ 42 MPH. anything more than that will make the EGTs climb.
HTH. Ill be watching this thread ;)
Reply #8July 01, 2008, 01:39:17 pm
orbitald
  • 53
High EGT on my AAZ
« Reply #8 on: July 01, 2008, 01:39:17 pm »
Well I was able to raise the boost to around 13psi and I can keep my EGT readings around 1300F now. On the longer hills I back off a bit and shift down to 3rd because it will probably rise up to 1400F if I dont. Raising the boost definitely lowered my EGTs!
I'm thinking maybe 14psi would be OK? I want a long lasting motor and hear conflicting reports on boost. Some say 20psi is fine while my mechanics say stick with 7-9psi.
Also, I have a Saab intercooler with a fan and I'm thinking about a liquid-air intercooler. Any recommendations for a Vanagon?
Thanks for your help.
David
Reply #9July 01, 2008, 01:54:48 pm
saurkraut
  • 904
High EGT on my AAZ
« Reply #9 on: July 01, 2008, 01:54:48 pm »
I've been running 20+ psi for a few years now.  Go for 20+ psi
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #10July 01, 2008, 02:15:57 pm
High EGT on my AAZ
« Reply #10 on: July 01, 2008, 02:15:57 pm »
Quote from: "saurkraut"
X2
Turn it up.
Reply #11July 02, 2008, 03:03:02 pm
andy2
High EGT on my AAZ
« Reply #11 on: July 02, 2008, 03:03:02 pm »
I would'nt run the k03/t2 past 15-17 psi as they are not bullet proof running 10 psi on stock engines.You can run the k14 with its bigger shaft at 18 psi forever and it will handle it.The k24/T3 can hold 21-22 psi all day long however they have much more lag than the k14.The k14 is the best turbo for a slightly modded 1.6 or 1.9 even my MK4 TDI will be getting a k14 to make 18 psi.
Reply #12July 03, 2008, 12:22:23 am
anto
High EGT on my AAZ
« Reply #12 on: July 03, 2008, 12:22:23 am »
Just to note peugeot supplied the younger 1.9 turbo diesel engines in the 306 model with a kkk k03 turbo and it was set standard to 14psi with a top mount intercooler so id say its safe enough to run at 14 or even higher.
Reply #13December 30, 2008, 11:07:21 am
orbitald
  • 53
High EGT on my AAZ
« Reply #13 on: December 30, 2008, 11:07:21 am »
Another question about this.
If I want to lower my egt going up large long hills on the highway (mountain driving) and I have three choices:
1) reduce fuel with max fuel screw
2) turn boost pin back around slightly
3) back star wheel up a little
Which should I choose and why?
Thanks,
David
Reply #14December 30, 2008, 11:23:26 am
blackdogvan
  • 574
High EGT on my AAZ
« Reply #14 on: December 30, 2008, 11:23:26 am »
You might want to read a bit about water/methanol injection. There are a few threads here & lots on info on the internets. For those once in a while long hills it would be nice to have. Your rear washer tank is already full of an almost perfect injection blend.
Real nice looking van BTW!
1991 Vanagon 1.9 mTDI
