Author Topic: Need a picture  (Read 2068 times)
June 15, 2008, 08:43:12 pm
webman
  • 14
Need a picture
« on: June 15, 2008, 08:43:12 pm »
I am looking for a picture showing where the power cable from the glow plugs runs.  The current system was been altered and the relay has been bypassed.  I would like to set it up factory again.
Its for a 91 Jetta
Reply #1June 21, 2008, 05:55:24 am
Need a picture
« Reply #1 on: June 21, 2008, 05:55:24 am »
no clue. I bypassed mine as I didn't like the old system. sorry I don't have a picture or anything just thought you needed a reply.
Reply #2June 21, 2008, 07:26:45 am
Need a picture
« Reply #2 on: June 21, 2008, 07:26:45 am »
On a 91 Jetta it should go from the bus bar to the firewall above the brake booster where there is a 50A strip fuse. From there it goes into the firewall to the fuse block
I think the above is for a mk1 but it should be the same
Reply #3June 22, 2008, 09:09:19 pm
webman
  • 14
Need a picture
« Reply #3 on: June 22, 2008, 09:09:19 pm »
If the fan relay was bad, would it affect the glow plugs from working?
Currently the system does not work unless I bypass the relay.  The light on the dash never lights up.  I have replaced the glow plug relay, but still nothing.
