Author Topic: white smoke, no power, backfires  (Read 7777 times)
June 13, 2008, 10:55:41 am
« on: June 13, 2008, 10:55:41 am »
Ok, I got my flywheel on and started it. It starts ok, seems to idle ok but smokes a ton and won't rev past 3k, plus it backfires some out the exhaust at 3k. With the timing light, timing seems to be where it was before the "incident". So I am assuming this provides more evidence towards bent valves unless the cam slipped? BTW, there is no blowby, so rings are still good.
Reply #1June 13, 2008, 11:00:30 am
« Reply #1 on: June 13, 2008, 11:00:30 am »
Oh, and I will be doing a compression check before I pull anything apart.
Reply #2June 13, 2008, 11:06:44 am
« Reply #2 on: June 13, 2008, 11:06:44 am »
did you verify cam timing?  bent valves suck :(
Reply #3June 13, 2008, 11:22:03 am
« Reply #3 on: June 13, 2008, 11:22:03 am »
No cam timing yet as I have to pull a bunch of stuff to get the valve cover off like the oil filled IC hoses. I can't get too dirty as I have to go shopping for a wedding gift when the wife gets home. Probably tomorrow afternoon after the wedding.
Reply #4June 15, 2008, 03:18:08 pm
« Reply #4 on: June 15, 2008, 03:18:08 pm »
Ok, the cam timing is still on. I checked compression in the 3 cylinders I can easily get to, and all are at 400 psi which doesn't seem like it indicates bent valves to me. What is the compression on a TDI supposed to be? Maybe I still have oil feeding in, and in the exhaust, accounting for the smoke. I have started wondering if the pump could be having some problem with the governor or advance. Any other thoughts?
Reply #5June 15, 2008, 06:28:35 pm
jasonsansfleece
  • 162
« Reply #5 on: June 15, 2008, 06:28:35 pm »
Dodgy injector?
Guy
Reply #6June 15, 2008, 07:14:21 pm
« Reply #6 on: June 15, 2008, 07:14:21 pm »
I found the timing advance cover was dripping a little. I took it off, sanded it smooth, cleaned everything and put it back on. I decided to advance the timing a little to see what happens. The smoke decreased dramatically, no more backfiring and it would rev much better. Maybe I was looking at the wrong mark when I checked the timing before. The question now is why did it change? I did find that two of the 3 front bolts were stripping out. I managed to get one out and weld a new bolt in place, but the nut just spun on the other one, not coming off. Maybe it rotated a little because of them. I will take the gear off tomorrow to cut off the nut and replace the other bolt.
As far as the turbo, I cleaned all the oil out of it that I could with it installed. With the turbo intake blocked off and the engine running, it quickly filled up to a certain point with oil and seemed to hold that level. I'll take it off tomorrow and drop by a local place to see what they say about it.
Reply #7June 15, 2008, 10:21:06 pm
burnt_servo
  • 278
« Reply #7 on: June 15, 2008, 10:21:06 pm »
when you dumped the clutch , i wonder if the timing belt jumped a cog ?
without actually hearing the engine , what you decribe sounds like the timing belt is out one tooth , or the cam has turned in it's sprocket .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #8June 16, 2008, 07:02:00 am
« Reply #8 on: June 16, 2008, 07:02:00 am »
The TB didn't seem any looser and I didn't have to move the pump anywhere near 1 tooths worth. The long ribbed belt for the alternator jumped 2 ribs however and is now too stretched out to stay in place.
Reply #9June 16, 2008, 02:21:43 pm
burnt_servo
  • 278
« Reply #9 on: June 16, 2008, 02:21:43 pm »
so that leaves the posibility of the cam slipping in  the sprocket a bit .  or maybe a partially sheared key on one of the other sprockets .
or maybe the timing  belt stretched  a bit ?
Reply #10June 18, 2008, 07:42:40 pm
« Reply #10 on: June 18, 2008, 07:42:40 pm »
No clue. I can't get the dial indicator on due to the location of a bunch of other crap like steering, hoses, footwell.
Reply #11June 19, 2008, 05:16:44 pm
« Reply #11 on: June 19, 2008, 05:16:44 pm »
Well, I got my turbo sort of half assed put together with other parts and put back on the engine. I also have the new pressure plate and clutch disc on. I had advanced the pump a little more after replacing one of the mounting bolts. I started it, and it was still smoking, so I got the timing light out again and checked. It was at 13 BTDC, so should have been plenty. I decided to check it while revving it a bit, and found the timing didn't change, so it looks like something is screwed in the pump, so I will have to pull it tomorrow.  :evil: At least the turbo isn't blowing any oil.
Reply #12June 19, 2008, 05:18:54 pm
« Reply #12 on: June 19, 2008, 05:18:54 pm »
BTW, pulling the wire off the solenoid on the timing spring cover (ALFV) retards the timing by about 10 degrees.
Reply #13June 19, 2008, 05:27:18 pm
« Reply #13 on: June 19, 2008, 05:27:18 pm »
Quote from: "jimfoo"
hmmm makes me wonder if you could wire that solenoid up to the accelerator cable somewhere with a switch.  so at idle it retards the timing for a nice quiet, less fuel hungry idle.  or would the timing advance react quick enough?
Reply #14June 19, 2008, 05:49:45 pm
« Reply #14 on: June 19, 2008, 05:49:45 pm »
Yeah, it seems to react instantly, so it would be possible.I found a graph of someones VagCom timing, and it looks like it should be at 4* at 1K rpm, and gets up to about 19* at 5k rpm.
