Author Topic: can someone help with this 1.6 turbo peice?  (Read 2522 times)
May 09, 2005, 06:42:53 pm
frankentoy
  • 51
« on: May 09, 2005, 06:42:53 pm »
this is the feed for the waiste gate?  i need to fix or replace it. i thought i could make a new peice of tubing and flare it but it doesnt look like it swivled..how did it screw on then.  im lost. thanks
ohiopowdercoating.com
Reply #1May 13, 2005, 03:51:21 pm
DieselMonkey
  • 124
pretty sure its....
« Reply #1 on: May 13, 2005, 03:51:21 pm »
I'm almost certain that is the coolant return line from a 1.6TD using the water cooled Garrett (T3 maybe). There are 4 tappings into the bearing housing on that turbo. Oil feed / return + Coolant feed / return. A couple of them are banjo type fittings.
The coolant was returned into the frost plug (middle one) at the back of the block, i imagine its a different type of frost plug with provision for the pipe and spring clip.
If its a turbo conversion your doing of some kind, and not using the water cooled Garrett, use a std frost plug and stop the flow of coolant from the block.
Hope this helps. DM
Reply #2May 15, 2005, 06:51:30 pm
frankentoy
  • 51
« Reply #2 on: May 15, 2005, 06:51:30 pm »
this is a garrett turbo but this line runs from a nipple off the front next to the front impellar and runs to the waiste gate. there are 2 female fittings on the front of the waistegate. this goes to the larger one thats says boost under it.
what is the other fitting for ? the smaller female opening.
how can i fix this peice?
Reply #3May 15, 2005, 07:26:12 pm
dieselweasel
  • 312
« Reply #3 on: May 15, 2005, 07:26:12 pm »
Just make a new one out of tubing and flare it...it has to swivel otherwise how would you screw it on?
Reply #4May 17, 2005, 12:30:38 pm
frankentoy
  • 51
« Reply #4 on: May 17, 2005, 12:30:38 pm »
i know, and looking at it.. it sure doesnt look like it swivles. thanks
