Metal Head Gasket on 1.6 solid lifter head?
Topic: Metal Head Gasket on 1.6 solid lifter head? (Read 3072 times)
June 12, 2008, 08:52:28 am
jackbombay
June 12, 2008, 08:52:28 am »
Is it possible to modify a 1.6 hydro head metal HG to fit a solid lifter head? What are the differences?
June 12, 2008, 09:41:29 am
June 12, 2008, 09:41:29 am »
Well I kinda did that.
I used a hydro head on a solid lifter block with the metal head gasket.
Click on the link in my sig and you can see what I did to make it work.
Almost 8000 miles so far and no leaks.
June 12, 2008, 10:35:36 am
shegel
June 12, 2008, 10:35:36 am »
what did that hole you filled do
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
June 12, 2008, 11:22:57 am
saurkraut
June 12, 2008, 11:22:57 am »
Cut some inserts from a rubber oil cap gasket and bolt 'er up:
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
June 12, 2008, 11:24:51 am
June 12, 2008, 11:24:51 am »
When I search for "metal head gasket" I get 4 pages of previous discussions, including this one with a picture of the hole in question:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=13211&highlight=metal+head+gasket
June 12, 2008, 01:03:04 pm
June 12, 2008, 01:03:04 pm »
Quote from: "shegel"
Who are you addressing?
If me, the hole in the head is a extra oil return hole, the hole in the block was a coolant passage.
June 13, 2008, 01:33:46 pm
jackbombay
June 13, 2008, 01:33:46 pm »
Thanks for the responses guys
I searched a bit, but was coming back with way to many results to sift through with what I entered.
I don't plan on doing a lot to this motor power wise, add an intercooler and add adjust the pump a bit, but that's it.
I think I'll be fine with a fiber HG, I left a message for myke_w and should have the parts on the way soon.
June 13, 2008, 07:23:18 pm
vanagonturbo
June 13, 2008, 07:23:18 pm »
http://www.vwdiesel.net/phpBB/viewtopic.php?t=14419
