Author Topic: 1.6 NA hangs after letting off throttle  (Read 1972 times)
June 12, 2008, 05:57:12 am
hamradio
  • 282
« on: June 12, 2008, 05:57:12 am »
Here's what's going on-
I resealed my pump, did the gov. mod while I had it apart.  If I rev up to 1/4 or 1/2 throttle in neutral, it takes a little while to return to idle.  If I'm running 2nd gear up to maybe 3/4 throttle, it sometimes run away, but I can kill it by shutting the engine off.
Is this from the governor mod?  I'm about to un-do it and see if it helps.
Thanks,
Devan
Reply #1June 12, 2008, 06:59:58 am
« Reply #1 on: June 12, 2008, 06:59:58 am »
Did you shim both springs or just the main spring?
Reply #2June 12, 2008, 07:17:49 am
Op-Ivy
  • 513
« Reply #2 on: June 12, 2008, 07:17:49 am »
Sounds like it could also be the full load screw. Try backing it out a bit first. It can be done with the pump still on so it would be best to try it first.
Reply #3June 12, 2008, 08:09:45 am
hamradio
  • 282
« Reply #3 on: June 12, 2008, 08:09:45 am »
iirc, I shimmed the smaller spring.
I'll try backing the screw out more.
thanks.
