Author Topic: WTB: 1.9 AAZ K03 Turbo Oil drain line  (Read 3914 times)
June 09, 2008, 10:05:41 pm
starrd
  • 128
« on: June 09, 2008, 10:05:41 pm »
Looking for a K03 turbo oil drain line.  Needs to have the 2 bolt flange for the turbo and the 18mm Banjo bolt for the 1.9 AAZ block.  I'm assuming this will work on a K24 turbo??
looks like this:
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #1June 10, 2008, 02:49:22 am
« Reply #1 on: June 10, 2008, 02:49:22 am »
the block side will fit but the flange for the turbo is too small for the K24.
you could take a K03 line & a K24 line and 'meld' them by re-crimping the oil return i believe.   i think that is what i might do too as the banjo fitting i have is in good shape.
