Non VW Group Diesel
Peugoet xl88
Topic: Peugoet xl88 (Read 4613 times)
June 09, 2008, 08:09:16 pm
TOW'D
Peugoet xl88
June 09, 2008, 08:09:16 pm »
Howdy Gang,
We were given a '79 Peugoet diesel with automatic trans.
Everything was in the trunk and we managed to get it back together
after doing a valve job and new HG
and it runs but with lots of white smoke.
It has a CAV pump
any tune up tips or links
thanks
hank
way too many projects not much time
June 09, 2008, 09:22:55 pm
Peugoet xl88
June 09, 2008, 09:22:55 pm »
White smoke could mean several things. In this case how ever it could mean your timing is way to retarded and or your glow plugs are not working as intended.
Is your coolant level staying up and not blowing out.?
June 10, 2008, 08:32:32 am
TOW'D
Peugoet xl88
June 10, 2008, 08:32:32 am »
coolant levels good
the PO used a lot of ether- there were 6 empty cans in the car when we got it
the white smoke doesn't seem to clear up after it gets hot
any links on adjusting the CAV pump?
thanx
hank
June 10, 2008, 08:38:02 am
Peugoet xl88
June 10, 2008, 08:38:02 am »
Sorry I'm not familiar with the Peugeot.
What does the CAV do?
June 10, 2008, 08:48:15 am
Peugoet xl88
June 10, 2008, 08:48:15 am »
It's a brand of injection pump. I think some Land Rovers had them also, so you might find some info by searching for LR Diesel pages as well.
June 11, 2008, 03:26:34 am
Patrick
Peugoet xl88
June 11, 2008, 03:26:34 am »
I've got a CAV pump on a 354 Perkins engine, timing is done by pulling the pump, lining up 2 slots where the pump shaft installs. Adjustment is done by a movable gear on the front of the engine that drives the pump shaft, not sure that your peugeot is the same. There is a little adjustment available where the pump mounts because the mounting holes are slotted too. Good luck............ A little extra advance makes a world of difference on the old perkins.
June 11, 2008, 06:32:25 am
TOW'D
Peugoet xl88
June 11, 2008, 06:32:25 am »
thanks for the replies guys
the Chilton manual we got to do the head doesn't help much for setting the pump--"take it to a Peugoet dealer"
I'll try adjusting the pump at the mounting bolts-
now I need to figure out which way the guts inside the pump turn
so I can figure out which way to turn it to advance the timing
off to Google land to see what we can find
thanx
hank
Non VW Group Diesel
Peugoet xl88
