Author Topic: Flat spot  (Read 1995 times)
June 09, 2008, 11:31:27 am
Mopar44o
  • 60
Flat spot
« on: June 09, 2008, 11:31:27 am »
My engine 1.9 aaz is pretty flat under 1800 rpms, espically with the A/C on. I have to ride the clutch and rev it to 2000 rpms to get the turbo to spool to get the car moving at a decent speed off the line. If i let it out slowly and get the car rolling first then use the gas, I can bury the pedle and it will slowly acclerate. Its slower than a guy on a bicycle :(
Is this engine normally that gutless under 2000 rpms? Or is it further tuning issues? I got it to idle good with the a/c on recently, what else can I do?
Reply #1June 09, 2008, 01:05:31 pm
Flat spot
« Reply #1 on: June 09, 2008, 01:05:31 pm »
mine is like that too... i'm pretty sure it has to do with the pump and or timing.
Reply #2June 09, 2008, 01:14:21 pm
Sc0rian
  • 25
Flat spot
« Reply #2 on: June 09, 2008, 01:14:21 pm »
mine has a flat spot just as im maxing out 3rd gear...
Reply #3June 09, 2008, 01:36:03 pm
Flat spot
« Reply #3 on: June 09, 2008, 01:36:03 pm »
Quote from: "Sc0rian"
fuel cutoff???  :lol:
Reply #4June 09, 2008, 05:26:27 pm
Mopar44o
  • 60
Flat spot
« Reply #4 on: June 09, 2008, 05:26:27 pm »
Talked to a mechanic today and he was saying that in 97+ the put a cut off switch for the a/c. So essentially it would kill the a/c when u accelerated to take the load off the engine.
So basicly I gotta a spool the turbo up or just kill the a/c when getting going from a stop...
Is that true?
