idle adjustment screw?? WHERE??
Topic: idle adjustment screw?? WHERE?? (Read 2107 times)
June 08, 2008, 02:30:29 am
James8485
June 08, 2008, 02:30:29 am »
when i increase the fuel i want to turn the RPM down to where is was and was wondering if anyone had a pic of the idle screw.....is it at the front of the IP where the throtle bumps up against is that what i adjust?
---------James--------
June 08, 2008, 05:46:49 am
June 08, 2008, 05:46:49 am »
#7 is the idle screw. #6 to which you are referring, is the residual fuel screw.
June 08, 2008, 07:17:00 am
gigaz2
June 08, 2008, 07:17:00 am »
damn! :x
on my 1.6TD pump I only have the residual and the full load one.. so I've been "screwing" with the wrong ones as well?
June 08, 2008, 08:00:05 am
James8485
June 08, 2008, 08:00:05 am »
well i know when i screwed that #7 last time it affected my cold start. i could pull my cold start and nothing would advance.....
sounds right?
