Author Topic: Difference between 1Y and ADG 1.9l  (Read 9316 times)
June 07, 2008, 04:08:41 pm
  • 1739
« on: June 07, 2008, 04:08:41 pm »
I've been digging all day but can't the same spec sheet with both the DI NA 1Y and ADG 1.9l motors. There must be a difference because i have one rating of 48hp and   about 98 ft/lbs for the ADG, barely any more than the 1.7 l KY motor i have now. I saw somewhere else that the 1Y puts out 68 hp and 100 ft/lbs of torque. Because the ADG is an industrial motor is it a question of fueling or cam or what?
Reply #1June 07, 2008, 07:58:27 pm
  • 1739
« Reply #1 on: June 07, 2008, 07:58:27 pm »
So after some more digging i think the 1Y motor is a SDI ecu driven 1.9l.
But also found out the other 1.9 l NA is AEF engine code. Isn't there some master list for every VW motor ever made ?
Reply #2June 07, 2008, 09:23:45 pm
« Reply #2 on: June 07, 2008, 09:23:45 pm »
ETKA should show it... as well as ELSA WIN
Reply #3June 09, 2008, 02:07:50 pm
spencebm
  • 686
« Reply #3 on: June 09, 2008, 02:07:50 pm »
i run an ADG in my car and it has the power rating on the timing cover.  if i remember correctly it has around 58 hp and somewhere between 120-140 lb ft tq i cant recall torque exactly
Ben Spencer
