Author Topic: glow plug light  (Read 5438 times)
May 07, 2005, 07:13:08 pm
fillmore
  • 60
    • http://fillmorenorthband.tripod.com
glow plug light
« on: May 07, 2005, 07:13:08 pm »
i know ive seen this topic on here before but i cant find it via the search function.
The Car = 87 jetta N/A
The Problem= the glow plug light goes off and on while driving. not just a fade in and out thing either it flickers and sputters around and is very annoying while driving at night
I think if i remember correctly someone before said something about water being the problem, like it leaked into either the actual glow plugs or the glow plug power conection or something. or maybe i just need to buy new glow plugs?
Reply #1May 07, 2005, 09:17:12 pm
chrissev
  • 694
Re: glow plug light
« Reply #1 on: May 07, 2005, 09:17:12 pm »
Quote from: "fillmore"
change the horn relay.  Weird, but true.
Reply #2May 16, 2005, 06:09:17 pm
fillmore
  • 60
glow plug light
« Reply #2 on: May 16, 2005, 06:09:17 pm »
nope not it
Reply #3May 16, 2005, 07:40:42 pm
dieseltech
  • 129
    • http://www.geocities.com/dean16v/Page_One.html
glow plug light
« Reply #3 on: May 16, 2005, 07:40:42 pm »
there are 2 coolant sensors in that car one is for the guage on the dash and the other is for the glowplug relay to tell how warm the engine is and decide if it needs glowplugs, these sensors are located on the water outlet on the right side of the head (away from the cam sprocket closer to the tranny) or sometimes on the later diesels they are on the front water neck on the front of the head.
anyway, if the wire or the sensor are bad for the glowplug circuit it can cause this, also on the early diesels the glowplug relay was located in the fuse box inside the car, sometimes these cars would develop water leakes around the windshield anf fry the relays or worse yet the fuse box itself, this can also cause the proble, described too. i would check and clean the contacts on the fuse box and relay, and test with a known good relay. and clean and check the wiring at the coolant temp sender. if this does not help, either the fuse box is shot or the voltage regulater behind the instrament cluster is bad.
good luck
86 td jetta power everything dd (update off the road for major resto).  97tdi bare bones, DD
and a private junkyard of various other vw/audi/bmw/peugeot/volvo/toyota diesels!!!
Cummins has the worlds record for being the most efficient engine ever!!!!!
for converting fuel into noise!
Reply #4May 18, 2005, 07:49:58 pm
fillmore
  • 60
glow plug light
« Reply #4 on: May 18, 2005, 07:49:58 pm »
awsome man thanks for the info ill check out my conections when i get a chance
