Author Topic: 88 golf diesel.....aaz purchased info needed  (Read 4240 times)
May 29, 2008, 07:49:30 am
lembot
  • 34
« on: May 29, 2008, 07:49:30 am »
My 1.6na diesel bit the dust and ive sourced a 1.9 td engine out of a passat on the cheap.I could do with a little help with the swap,what exactly needs to be changed wiring wise,will my old gearbox fit,is there anything else i should look out for?any info/help appreicated :wink:
soot
Reply #1May 29, 2008, 09:16:30 am
Quantum TD
  • 1195
« Reply #1 on: May 29, 2008, 09:16:30 am »
If it's a standard 1.9TD (not a TDi), then it will just drop right in, with no extra wiring issues, except for the alternator (just put the big red wire(s) on the large terminal), and wire up your glo plugs. There is a heating element on the CrankCase Breather Valve (CCV), right where the breahter tube enters the intake tube. You could live without it, or try to wire it up. Also, you may have a temp-controlled timing advance mechanism. I'm sure the wiring for that is pretty simple too, but I have not dealt with it.
Good Luck
Reply #2May 29, 2008, 09:39:48 am
« Reply #2 on: May 29, 2008, 09:39:48 am »
will the exhaust work?
Reply #3May 29, 2008, 10:21:55 am
« Reply #3 on: May 29, 2008, 10:21:55 am »
Quote from: "jtanguay"
If you can put the mk2 TD upper downpipe on it will bolt up to the NA lower downpipe. If you have a K03 this is a bit trickoier because of a different downpipe flange.
Power steering (if equipt) is almost a direct swap, just use the 1.9 pump and the 1.6 lines.
Tranny bolts up no problem
Reply #4May 29, 2008, 11:09:41 am
lembot
  • 34
« Reply #4 on: May 29, 2008, 11:09:41 am »
thanks for the help guys is there anything else i need to know?
soot
Reply #5May 29, 2008, 02:57:26 pm
Patrick
  • 1034
« Reply #5 on: May 29, 2008, 02:57:26 pm »
There's one more thing. Use the downpipe from the 1.9 if it will fit (depending what car it came out of) much neater.
Oh, and the other thing is you will be AMAZED at the difference in power if the 1.9 is in any kind of decent shape!
Reply #6June 02, 2008, 02:37:09 am
lembot
  • 34
« Reply #6 on: June 02, 2008, 02:37:09 am »
Ok thanks for the help,Just one more question,do i need any parts of the loom from the donor car?
soot
Reply #7June 02, 2008, 07:24:26 am
« Reply #7 on: June 02, 2008, 07:24:26 am »
The wiring is simple but the harness is quite different.... AAZ engines have a large circular multiconnector that bolts on to a bracket on the head... all of the engine wiring runs thru the connector (IP, glow plugs, oil pressure senders, etc etc)
So, you can snag the multiconnector with a pigtail from the donor car, or just delete the entire thing and run the original wiring to the various spots.
