Author Topic: Camshafts  (Read 4543 times)
May 27, 2008, 03:38:16 am
LoneWolf
Camshafts
« on: May 27, 2008, 03:38:16 am »
is a 1.5 N/A diesel camshaft different to a 1.6TD camshaft?
Reply #1May 27, 2008, 03:07:11 pm
DieselKraut
  • 54
Camshafts
« Reply #1 on: May 27, 2008, 03:07:11 pm »
I need to know the same thing about putting a 1.6N/A cam in a 1.6TD.
'80 Rabbit 1.5 IDI 126,00Mi Down but not out!
'83 Quantum 1.6 TD IDI
'90 Passat Gasser
Reply #2May 27, 2008, 07:52:31 pm
Quantum TD
  • 1195
Camshafts
« Reply #2 on: May 27, 2008, 07:52:31 pm »
Not sure about the 1.5, but the 1.6 NA and TD cams are the same, so long as they're the same motor type (Hydraulic or Mechanical). So, you can run a 1.6NA mechanical lifter cam in a 1.6TD mechanical lifter head, and vice versa. Same for hydro.
Now, that's just going by part numbers. I've been told you can run just about any ca in any model. So, mechanical cam can be run in a hydro head.
I'm currently running a 1.9 TDI cam in my 1987 1.6NA. It works fine in terms of idling, but it seems to be light in the torque dept (high lift, short duration, vs. less lift and longer duration).
So, I guess the bottom line is, try whatever you like. I don't think it will do damage, except for changes in power, torque or economy.
Please correct me if I'm wrong out there.
Reply #3May 27, 2008, 08:01:23 pm
Camshafts
« Reply #3 on: May 27, 2008, 08:01:23 pm »
I seem to remember reading someone saying that mixing hydraulic and solid lifter cams can result in valve damage because one has more lift then the other. I can't confirm or deny this though. Turn the engine over by hand a few times first to be safe.
Reply #4May 28, 2008, 12:22:33 am
LoneWolf
Camshafts
« Reply #4 on: May 28, 2008, 12:22:33 am »
the 1.5 has a higher lift than the 1.6 as it turns out
 no more funny tapping noises :D
Reply #5May 28, 2008, 04:05:30 am
DieselKraut
  • 54
Camshafts
« Reply #5 on: May 28, 2008, 04:05:30 am »
So if a 1.5 cam is put in a 1.6 is there an issue with valve to piston clearance?
'90 Passat Gasser
Reply #6May 28, 2008, 03:20:56 pm
LoneWolf
Camshafts
« Reply #6 on: May 28, 2008, 03:20:56 pm »
i think the N/A  shafts are pretty compatbale, but not so much the TD, but im open to corrections if im wrong :?
