General Information
Troubleshooting
Ok, now I'm pissed
Topic: Ok, now I'm pissed (Read 4231 times)
May 24, 2008, 05:26:40 pm
Ok, now I'm pissed
May 24, 2008, 05:26:40 pm »
The day before yesterday I had fuel leaking out the timing advance(cold start) as the clip had come off. I stayed up late fixing it and replacing the o-ring under the cover. Today I go take it for a drive and start smelling diesel again. I pull over to look and it is pouring fuel out again as the new clip was nowhere to be seen. Luckily I was able to jam a screwdriver in to hold the seal in place.
Is it supposed to have a c clip or snap ring? I had put a c clip on, and maybe the internal pressure is too much for it? I'm almost ready to drill and tap the shaft for a bolt to hold it in place. :evil:
May 24, 2008, 09:40:56 pm
Dakotakid
Ok, now I'm pissed
May 24, 2008, 09:40:56 pm »
It's been awhile, but there is a C clip there.....as I recall. Perhaps it fractured as you installed it and then fell apart after awhile?
May 24, 2008, 10:00:39 pm
Ok, now I'm pissed
May 24, 2008, 10:00:39 pm »
Weird thing is I never touched the original. It just vanished. Then the replacement didn't last an hour before it was gone as well.
May 25, 2008, 02:39:58 pm
Ok, now I'm pissed
May 25, 2008, 02:39:58 pm »
Ok, think I got it figured out. There was supposed to be a washer between the linkage and e clop. Without it, there was probably too much leverage on the clip, allowing it to be bent.
General Information
Troubleshooting
Ok, now I'm pissed
