Author Topic: calling all nitro and methanol injection guys  (Read 2085 times)
May 20, 2008, 11:14:44 pm
shegel
  • 312
« on: May 20, 2008, 11:14:44 pm »
first hte methanol guys. how did you set yours up. did u use a washer pump(what i was thinking) what did you use for sprayers(i wasthinking maybe garden misters) where did you put the sprayers on your manifold
now the nitro guys what jet have you found to work well. i probably will only use it 1 time a day for a big hill by my house what size tank do you use. did you buy a kit or build one wot switch or push buttion switch....
thanks again,
steve
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #1May 20, 2008, 11:15:02 pm
shegel
  • 312
« Reply #1 on: May 20, 2008, 11:15:02 pm »
by the way its for my golf
Reply #2May 21, 2008, 05:02:48 am
« Reply #2 on: May 21, 2008, 05:02:48 am »
i bought a kit off ebay.  came with a 150 psi pump.  basically a sprayer pump that can be bought at princess auto.  sureflo i believe its called.
still haven't installed it, but the best way is to pull off the top piece of the 1.6TD manifold, and then drill & tap for the fitting.  which is already done on mine.  when i get it running i'll let you know how she goes.  i'm hoping for at least 10 hp gain or more depending on fueling  :twisted:
some people advise against injecting pre-turbo, but hillfolk'r has been doing it for a while and hasn't reported any damage thus far.  just remember that if you inject post turbo, to have more pressure than boost pressure.  not sure if a washer pump can put out enough?  maybe with a misting nozzle or something...
Reply #3May 21, 2008, 07:50:54 am
shegel
  • 312
« Reply #3 on: May 21, 2008, 07:50:54 am »
well im not sure how much trouble i'll get in but i dont think im goin to turbo my car any time soon... :roll:
Reply #4May 25, 2008, 07:59:40 am
shegel
  • 312
« Reply #4 on: May 25, 2008, 07:59:40 am »
well i did it. i ran a secondary wahser pump with a misting nozzle from home depot but i am running from the stock washer tank. so thats not a big deal. i didnt have to run a second tank because of this. when i use the injecton i can tell a difference in the higher rpm's (using the washer fluid as fuel) and it pulls a lot harder in the upper rpms too
