Author Topic: IP timing- help needed with metric dial caliper  (Read 3487 times)
May 20, 2008, 04:36:08 am
haybayian
  • 155
« on: May 20, 2008, 04:36:08 am »
Sorry guys for asking such a pedestrian question ( somewhat redface).
I am trying to set my IP timing and whereas I have no problem with the operation itself I don't know how to read the metric dial caliper  named HOREX sold to me by Samstag Sales in the US. I am used to instruments in inches, but my imperial  dial caliper is too wide and does not fit to the extension. Could anyone help with this metric thing.
Thanks.
Haybayian
Keep it simple if you can.
Reply #1May 20, 2008, 04:55:22 am
flapjack
  • 283
« Reply #1 on: May 20, 2008, 04:55:22 am »
1 inch = 2.54 cm
1 inch = 25.4 mm
inches X 25.4 = mm
signature
Reply #2May 20, 2008, 06:54:53 am
haybayian
  • 155
« Reply #2 on: May 20, 2008, 06:54:53 am »
Quote from: "flapjack"
1 inch = 2.54 cm
1 inch = 25.4 mm
inches X 25.4 = mm
My problem is not metric conversion but  to make sense of the digits on the dial.
Thanks anyways.
Reply #3May 20, 2008, 07:03:28 am
« Reply #3 on: May 20, 2008, 07:03:28 am »
So you have a metric dial then?
Timing set to 1mm lift?
What are you shooting for? As in what are you wanting to set the timing at.
Reply #4May 20, 2008, 07:04:15 am
gigaz2
  • 626
« Reply #4 on: May 20, 2008, 07:04:15 am »
you should post a picture of the dial then.
I also had a doubt about the setting, so if you post it it can be answered at the same time :D
Reply #5May 20, 2008, 07:53:30 am
flapjack
  • 283
« Reply #5 on: May 20, 2008, 07:53:30 am »
tell us what the dial says.  it usually says    > < = .1 mm or something like that. Means each of the smallest marks on the dial = .1mm
One full rotation of the dial on mine = 2mm, so half a rotation = 1mm
signature
Reply #6May 20, 2008, 08:18:10 am
haybayian
  • 155
« Reply #6 on: May 20, 2008, 08:18:10 am »
The timing I am setting is that of the IP.
My dial is graduated from zero to 50 and has a smaller rotation number dial.
I ballparked the 2.5 mm preload.
Zeroed the dial  + 1 mm preload. This dial seems to make two complete turns for one mm.
I figured that the hand should be back to  the 24 to 34 reading on this dial.
What do you folks read when you complete the IP timing routine in metric?
Thanks for your time.
Haybayian.
Reply #7May 20, 2008, 01:26:51 pm
« Reply #7 on: May 20, 2008, 01:26:51 pm »
Sometimes in a case like this I find a way to test the theory... have you got something of a known thickness that you can measure and "teach" yourself how to read the screen ?  Feeler gauge or spark plug gapper ??
I know I know... what's a spark plug.  :wink:
Reply #8May 20, 2008, 01:54:00 pm
rallydiesel
  • 1880
« Reply #8 on: May 20, 2008, 01:54:00 pm »
Each tick is .01mm for this one. So 2 revolutions would equal 1mm.
So after zeroing the gauge when the IP piston is fully retracted, the gauge should rotate exactly twice from your zero mark to TDC. That's kind of a weird gauge. Too precise really.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #9May 20, 2008, 05:12:31 pm
haybayian
  • 155
« Reply #9 on: May 20, 2008, 05:12:31 pm »
Quote from: "rallydiesel"
That's the dial I have and...
I am beginning to get the picture.
Thanks you guys for taking the time to help.
Haybayian
Reply #10May 20, 2008, 05:16:45 pm
haybayian
  • 155
« Reply #10 on: May 20, 2008, 05:16:45 pm »
Quote from: "Vincent Waldon"
Yes Vince, that's what I have done. The feeler gauge showed  0.5mm for a full rotation
Haybayian
