Author Topic: Cracks between valves:S  (Read 4531 times)
May 18, 2008, 01:08:59 pm
LoneWolf
« on: May 18, 2008, 01:08:59 pm »
ive got the  head of my GTD, and it looks like its cracked between the valves on every cylinder :?
 is this a common occurance?
Reply #1May 18, 2008, 01:29:48 pm
bigblockchev
  • 271
head cracked
« Reply #1 on: May 18, 2008, 01:29:48 pm »
This is very common. There is even a spec for it in the Bentley manual, too much and you turf the head, less than that it is ok to reuse. Generally less than 1mm is normal. Cracks in other areas are a different matter however. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #2May 18, 2008, 01:32:58 pm
LoneWolf
« Reply #2 on: May 18, 2008, 01:32:58 pm »
mine are just between the valves.
 the car threw its coolant out of the exhaust, so i stripped it, and couldnt find anything wrong with the gaskett, so i rebuilt it with a new steel HG and set it up again, then it wouldnt run, but what it did do was to pressurise the coolant bottle so much that it split right open!
 i stripped it down AGAIN this morning and tahts when i noticed the cracks.
 is it safe to say that the heads damaged and thats whats making it blow up and not run?
Reply #3May 18, 2008, 05:04:28 pm
bigblockchev
  • 271
« Reply #3 on: May 18, 2008, 05:04:28 pm »
The coolant could be coming out from a blowthrough in the casting in the prechamber , this happened to me. The head looked ok on the surface but leaked when installed. Either way it is shot. You may be able to find a machine shop to pressure test it before condeming it. Cheers Dan
2000 Jetta TDI
Reply #4May 19, 2008, 12:07:28 am
LoneWolf
« Reply #4 on: May 19, 2008, 12:07:28 am »
so i could be better off putting in a new engine and saving the time really. ive got another head, but i didnt think about the block being damaged :(
Reply #5May 19, 2008, 12:18:23 am
DCC
  • 184
« Reply #5 on: May 19, 2008, 12:18:23 am »
Quote from: "LoneWolf"
Well, the cracks are very, very common. Almost every GTD head I've seen with some mileage had them. Have that head tested before arriving to any conclusion. Maybe the block is ok.
Reply #6May 19, 2008, 07:14:35 am
« Reply #6 on: May 19, 2008, 07:14:35 am »
Test what you have if it isn't crazy expensive. Who's to say the other engine won't have issues.
