Author Topic: how many have broken cams ?  (Read 2789 times)
May 17, 2008, 03:43:56 pm
  • 1739
« on: May 17, 2008, 03:43:56 pm »
So i posted in non vw group because i have a good customer with a volvo 760 with the 6 cyl vw/audi motor. I was asking if there were any spare heads out there because his timing belt broke or chewed up; at least that's what i thought . Finally got it into the shop, decided to get to the whole belt  before pulling the head or even the valve cover. When i tried to remove the v belt pulley i realized the crank pulley bolt was completely loose. Then i removed the valve cover and low and behold the cam is broken after the # 1 cyl lobes. I've only seen this once before and was wondering if anyone has. I will post pics in a couple of days.  Quite amazing when you see how thick the cam stock is.
Reply #1May 17, 2008, 03:56:11 pm
Baxter
« Reply #1 on: May 17, 2008, 03:56:11 pm »
Seen it in a LT55, when the docile mechanic didn't check he had it timed up right and cranked it over without turning it manually.
twat.
He also left crank pulley loose, as we found out later.
Expensive mechanic he was, it only started off as a head gasket replacement, ended up being off the road for months!
Reply #2May 18, 2008, 08:06:11 am
DCC
  • 184
« Reply #2 on: May 18, 2008, 08:06:11 am »
Here you go:
Reply #3May 18, 2008, 06:06:27 pm
« Reply #3 on: May 18, 2008, 06:06:27 pm »
I had a stock 400 M ford do this in 4 places. Never heard of it before or since. The head was used and it had been stored for like 6 years and all of the people I talked to said that was probably what did it. I didn't think so but like I said never heard of it. sucks for you I hope it all works out.
Reply #4May 18, 2008, 06:31:36 pm
bvolks73
  • 183
« Reply #4 on: May 18, 2008, 06:31:36 pm »
I've seen it happen twice on 2.2L Dodge Shadow motors but never on any VW motors so far.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #5May 20, 2008, 05:15:09 pm
  • 1739
« Reply #5 on: May 20, 2008, 05:15:09 pm »
holy crap i'm gonna have to post some pics. the cam is in 5 pieces.!
and there doesn't seem to have any damage to the valves...
