Author Topic: Will it work?? I don't see why it shouldn't?? (new member!)  (Read 10922 times)
Reply #30May 18, 2008, 04:18:48 am
Baxter
« Reply #30 on: May 18, 2008, 04:18:48 am »
Reply #31May 18, 2008, 05:50:23 am
LregG
  • 26
« Reply #31 on: May 18, 2008, 05:50:23 am »
cheers simon, i'll read that when i'm not hungover, probably tomorrow lol
Reply #32May 18, 2008, 06:52:23 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #32 on: May 18, 2008, 06:52:23 am »
Er,,? Is the flow from the GLader sent through the cambox to the rear of the engine? :? Assuming it is, and there is a camshaft in the way does that mean the entire engine is pressurized? Bizarre! :P
Reply #33May 18, 2008, 08:37:57 am
LregG
  • 26
« Reply #33 on: May 18, 2008, 08:37:57 am »
Quote from: "smutts"
It may seem that way mate but there is a sealed pipe running through the rocker cover, it is used for the boost return to the 'charger
Reply #34May 25, 2008, 07:00:10 am
sjampoo
  • 11
« Reply #34 on: May 25, 2008, 07:00:10 am »
Yes: the pipe inside the valvecover is sealed,. but in my setup, there is no return :)
(you can see a pipe yes, on the metal -intake, that 'looks' like a blow-off or return-thingy, but its just a dead end :)
I used original Polo 2 G40 hoses and tubing, which are rare. Didn't want to cut it up in pieces, and I do need the breather (from crank-housing), to 'oil/lubricate' the G-chargers internals.. (which you can see towards the rear).
it is 'lean' as in: It could cope with some more fuel, but there just isn't a possibility to give it more fuel without a higher idle. Governor needs to be modded (slightly): when I floor it at idle, it doesn't smoke - at all - : Not to say that it has to smoke, but it just isn't - at all -
Anyways: love the torque; it's just there. From 1500 to 4000 rpm: all the way. No need to rev it at all..
Volkswagen Polo 86c 1982 1.4D with G40-supercharger (running veggy power)
http://www.volksforum.com/forum/showthread.php?t=22161
Reply #35March 27, 2010, 06:57:25 am
polo_td
  • 65
Re: Will it work?? I don't see why it shouldn't?? (new member!)
« Reply #35 on: March 27, 2010, 06:57:25 am »
Any progress????
