Injector Return line: is there an order?
Topic: Injector Return line: is there an order? (Read 2227 times)
May 15, 2008, 07:16:23 am
flapjack
May 15, 2008, 07:16:23 am »
Does it matter how you hook up the injector return lines?
Are the two hose barbs directional?
No matter which barb I cap off, it leaks. I changed the cap and the lines on all the injectors.
signature
May 15, 2008, 07:35:20 am
May 15, 2008, 07:35:20 am »
Not directional. Is there possibly a blockage somewhere on the pump? Normally #1 gets a cap and #4 goes to the pump, but it shouldn't matter.
May 15, 2008, 07:49:58 am
flapjack
May 15, 2008, 07:49:58 am »
If I take off the line from the injector back to the pump and blow into it, should I be able to drive the fuel back to the filter?
signature
May 15, 2008, 09:21:56 am
May 15, 2008, 09:21:56 am »
No clue as I've never tried it. I would think it should go to the return line if anything. I don't see anything in my pump book either that says what path the returned fuel takes.
