Hydraulic and mechanical cam interchangability
Topic: Hydraulic and mechanical cam interchangability (Read 2067 times)
May 10, 2008, 10:19:34 am
Dakotakid
May 10, 2008, 10:19:34 am »
I read an earlier post which discussed this topic, but there did not seem to be a definitive answer.
Can I run a solid lifter camshaft in a hydro head? Are there any negative consequences?
May 10, 2008, 04:23:51 pm
Fisher
May 10, 2008, 04:23:51 pm »
There is lots of banter about this and everyone says something different. I put an 82 Mechanical Cam in an 86 Hydraulic Head engine that I completely rebuilt and it worked and ran fine. If fact after I started it up I completely forgot about it.
May 10, 2008, 05:07:49 pm
May 10, 2008, 05:07:49 pm »
i always heard you couldn't do it but i never knew why
May 10, 2008, 05:39:06 pm
May 10, 2008, 05:39:06 pm »
I *thought* I read that someone posted the innerbase circle was larger on the mechanical cam and caused the valves to hang open... but I guess not if you`ve done it.
