Author Topic: TD Pump question  (Read 2222 times)
May 10, 2008, 08:32:31 am
rabbitpower
  • 45
TD Pump question
« on: May 10, 2008, 08:32:31 am »
I have an 86 TD 1.6. I also have a 92 NA engine that has a pump that looks very similar. Can parts be swapped between these pumps? What are the major differences. Great site by the way!
Reply #1May 10, 2008, 02:13:00 pm
TD Pump question
« Reply #1 on: May 10, 2008, 02:13:00 pm »
What parts do you want to swap and why?
They are very similar but very different at the same time.
Reply #2May 11, 2008, 05:55:17 am
rabbitpower
  • 45
TD Pump question
« Reply #2 on: May 11, 2008, 05:55:17 am »
I wanted to know in case the pump on the TD dies. That and i would like to experiment a little. I have only had an IP apart a few times and never knew you could modify them. I also noticed that the 92 cyl head has the same part number as the 86 TD. I had heard somewhere that Vw just canned the TD speacialties ( Coated valves and tougher alloy) in favor of just making the NA and TD heads the same after a certain year. Is this true?
