Author Topic: Rally rabbit- A1 chassis  (Read 4412 times)
May 09, 2008, 10:14:01 pm
TDDrew
  • 46
« on: May 09, 2008, 10:14:01 pm »
Just wondering if anyone has any recommendations for springs and shocks for off road rally type driving for the A1  chassis. it's for a 79 rabbit.
Thanks!
79 Rabbit 1.6 Diesel 4 door
79 Rabbit 1.5 Diesel 2 door- with a/c, oooooo.
Reply #1May 10, 2008, 01:34:14 pm
hamradio
  • 282
« Reply #1 on: May 10, 2008, 01:34:14 pm »
I don't personally know, but there is a wealth of information around the vortex in the mk1 forum, if you ask.
Reply #2May 15, 2008, 09:42:18 pm
TDDrew
  • 46
« Reply #2 on: May 15, 2008, 09:42:18 pm »
k, thanx, ill check into it.
Reply #3May 19, 2008, 06:45:03 pm
ODwyerPW
  • 103
    • http://www.Espanglish.com.mx
Rally Rabbit
« Reply #3 on: May 19, 2008, 06:45:03 pm »
For my Rabbit TD, I am fitting the Springs off of a Cabriolet.  The higher weight, therefore higher spring rate, should raise my car just a bit.  I have the springs, I just have to get around to fitting them.
83 Rabbit LS Turbo Diesel
Reply #4May 20, 2008, 08:35:47 am
VelocityConservation
  • 92
« Reply #4 on: May 20, 2008, 08:35:47 am »
My friend has a rally rabbit.  It is a gasser though.
He says:
Get Bilstein Rally Struts, get them without Spring sleeves.
Get standard 2.5" coilover sleeves (he uses Ground Control, but any manufacturer will work).
Solid mounts are not necessary, stock mounts work fine and tend to be better for the body (chassis).
You will need to reinforce the front strut towers around the top.
He uses Eibach springs 275lbs/11" in the front and 175lbs/10" in the rear (he uses the extra length to get the height w/o having to go big on the spring rates)(he tried 250/150, too soft and 300/200 much too stiff)
The real issue is the lower control arm mounting points.  Stock they need to be pushed back into place and rewelded after EVERY rally.  He has a bar welded between both lower control arm mounts now.  There are other ways to brace them up, but they must be braced or they will fail.
90 TD Jetta, NA to TD swap completed '07
Reply #5May 21, 2008, 01:02:05 pm
VWralley
  • 50
« Reply #5 on: May 21, 2008, 01:02:05 pm »
Road Rally....are you talking like a time/distance rally or full on rally? they are MUCH different in car setup.
i agree with most of what was said above, i do the engine tuning on the Demon Rally rabbit (demonrally.com) an they use bisteins hd's valved for rally, mk2 springs up front with one coil cut, an rear stock rabbit springs.
they consistatly run in the top 10 overall, an last season in Michigan took home the group 2 win. its a very good setup :)
77 rabbit 16v MSnS
85 Audi 4KQ
81 Rabbit 4dr diesel
Traksclothing.com Demonrally.com
Reply #6May 24, 2008, 06:42:58 pm
mainer
  • 126
« Reply #6 on: May 24, 2008, 06:42:58 pm »
put mk2 sturts and springs in it. You get about a 3 inch lift and alot stiffer spring rate.
Cooper
_________________
Accidental death and dismemberment insurance Forum
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #7May 28, 2008, 10:43:01 pm
TDDrew
  • 46
« Reply #7 on: May 28, 2008, 10:43:01 pm »
Ohh, wow! Spring rates!  :D
 Thanks for all of the excellent info. I was thinking to myself when I was under the car that it looked like it needed a brace on the front control arm mounting, didn't know it was that important. Glad I don"t have to find out the hard way.
I'm not doing anything professional, but I do love to go thrash the VW off road and I want to jump it too.  I'm thinking the coil over setup will best suit my driving needs.
