Author Topic: AAZ parts for sale  (Read 4263 times)
May 07, 2008, 06:56:09 pm
AAZ parts for sale
« on: May 07, 2008, 06:56:09 pm »
All these parts were pulled from a scrap yard. I don't know their condition or mileage. The car had a bad headgasket
1) AAZ head, complete with valves, cam and cam cover. No injectors. $50
Might be warped. Has the normal cracks between the valves and also a crack from a #2 valve (forget what one) to the precup. The headgasket failed between #3 and #4. It was removed using the proper steps.
2) K14 turbo. Minimal shaft play. $120 - pending
3) Exhaust manifold - K14, T3, K24 etc $60 - pending
4) AAZ intake manifold $60 - SOLD
5) AAZ injector lines $50 - pending
6) 4 AAZ injectors - $50 -SOLD- should be rebuilt. I work with Giles so I can bring them in and have them tested/freshened up for the regular price.
7) AAZ valve cover - upper, outer plastic piece $10
8) AAZ vacuum pump with hose - $35 - SOLD
9) intake hose for K14 - $15
Reply #1May 07, 2008, 07:48:39 pm
starrd
  • 128
AAZ parts for sale
« Reply #1 on: May 07, 2008, 07:48:39 pm »
PM sent on intake, injectors and vacuum pump
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #2May 07, 2008, 09:40:16 pm
thedeezel
  • 62
AAZ parts for sale
« Reply #2 on: May 07, 2008, 09:40:16 pm »
pm sent
I'll try being nicer, if you try being smarter...
Reply #3May 14, 2008, 05:48:33 pm
AAZ parts for sale
« Reply #3 on: May 14, 2008, 05:48:33 pm »
This head is most likely warped. Therefore it is free for pickup only. Maybe a delivery in the GTA.
Reply #4July 02, 2008, 08:27:16 pm
duff
  • 18
AAZ parts for sale
« Reply #4 on: July 02, 2008, 08:27:16 pm »
do you still have the turbo and will it fit a 1.6 TD?
